Superbird wing nuts. #1296845
09/03/12 11:57 PM
09/03/12 11:57 PM
Nebraska
4406bbl Offline OP
4406bbl  Offline OP
Nebraska
Can anyone tell me what size the washers are on the nuts that hold the wing on? The wing has studs, wing washers are in the quarters, and I have the brackets that go to the trunk floor brackets, just need to know diameter of the washer. Car is a basket case from 1976, so far every bolt has been there but nothing is marked, just a 5 gallon bucket of bolts.
Re: Superbird wing nuts. [Re: 4406bbl] #1296846
09/04/12 09:25 AM
09/04/12 09:25 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
9/16" nut with 1" captive washer, USS course thread.
Re: Superbird wing nuts. [Re: 62maxwgn] #1296847
09/04/12 01:32 PM
09/04/12 01:32 PM
GA
roadrunninMark Offline
GA
any pics of the bird?
Re: Superbird wing nuts. [Re: roadrunninMark] #1296848
09/04/12 02:40 PM
09/04/12 02:40 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Maybe !
Re: Superbird wing nuts. [Re: 62maxwgn] #1296849
09/04/12 05:59 PM
09/04/12 05:59 PM
Nebraska
4406bbl Offline OP
4406bbl  Offline OP
Nebraska
Thanks, I found 8 of those with no paint on them. The wing support brackets have the bolts in them that hold them together but I need to know what bolts bolt them to the trunk floor. I also found the triangle bracket that holds the jack down, is the wingnut for that black or silver? One last item is the windshield chrome, any pics of the exact 5 screws that hold them on? Spent the weekend finding all the parts and bolts, bagging and marking everything. I also found 4- 1 1/4" diameter extra thick washers,cad plated with a 3/8 hole with yellow paint and red primer on them so I would bet they came from this car, wing related? Thanks for the help.
Re: Superbird wing nuts. [Re: 4406bbl] #1296850
09/04/12 07:30 PM
09/04/12 07:30 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Check your email.
Update,your email doesn't work !!
Re: Superbird wing nuts. [Re: 62maxwgn] #1296851
09/04/12 07:59 PM
09/04/12 07:59 PM
Nebraska
4406bbl Offline OP
4406bbl  Offline OP
Nebraska
Yes, I have been away awhile, will go in and change it. Thanks
