Page 4 of 11 1 2 3 4 5 6 10 11
Re: Reserection of my old W8 Bullet [Re: 440W8 Duster] #1296695
10/01/12 10:58 PM
10/01/12 10:58 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Did you get a chance to snap a pic of your belly pan? I need to do something. Who k frame do you have?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Reserection of my old W8 Bullet [Re: fishy340] #1296696
10/01/12 11:36 PM
10/01/12 11:36 PM
Out West
408strokerdart Offline OP
Out West
them exhaust ports look kinda purty!
They do! Brett does nice work.
Re: Reserection of my old W8 Bullet [Re: 440W8 Duster] #1296697
10/01/12 11:38 PM
10/01/12 11:38 PM
Out West
Out West
Brian Who did the valve covers?
Hydrocoating of Texas. They are in Cedar Hill, about 15 miles from me. They do nice work and pretty reasonable prices.
Re: Reserection of my old W8 Bullet [Re: 1967dartgt] #1296698
10/01/12 11:41 PM
10/01/12 11:41 PM
Out West
Out West
I don't have any pics of the belly pan/drip pan on my computer. The k-frame is mine...custom built for the strut front. I did it before there were many other options out there. I think it is one of the things that makes my car as light as it is.
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296699
10/02/12 07:35 AM
10/02/12 07:35 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
What strut did you put in the car Brian?
Alan Jones
Re: Reserection of my old W8 Bullet [Re: LA360] #1296700
10/02/12 09:38 AM
10/02/12 09:38 AM
Out West
Out West
It is a fabricated strut that takes standard Monroe strut cartridges and a 12" coil over spring. If I had it to do again, I would just use a double adjustable race strut. Funds were tight when I did it and it works great and is a dream at 150+. Just alot of work to get everything right. They are made from moly tubing and laser cut plate with aluminum adjuster tubes.
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296701
10/02/12 04:50 PM
10/02/12 04:50 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Can't wait til you get that bad boy together. Looking forward to seeing it run down the track.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Reserection of my old W8 Bullet [Re: ChrgrCuda] #1296702
10/06/12 10:56 AM
10/06/12 10:56 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
Ok the question i have is what are you looking to get out of it now?
Re: Reserection of my old W8 Bullet [Re: Otherlane] #1296703
10/06/12 04:23 PM
10/06/12 04:23 PM
Out West
Out West
Goal is for it to stay together so I can run the piss out of it and pick up the pace to be able to go 5.80 in the heat (so 5.65 to 5.70 in good air). Also, want my 8 second time slip.
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296704
10/06/12 05:12 PM
10/06/12 05:12 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
5.70 in good air. Maybe I need to send an intake down....LOL
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296705
10/06/12 05:16 PM
10/06/12 05:16 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
that thing should run 8's in 110 deg heat,air like here where i live if the car is right,,,i'd say 8.60's/70's
Re: Reserection of my old W8 Bullet [Re: W5DART66] #1296706
10/06/12 05:44 PM
10/06/12 05:44 PM
Out West
Out West
Man....you really want to spoil things don't you?
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296707
10/06/12 05:47 PM
10/06/12 05:47 PM
Caledonia, Ohio
BigDog68Dart Offline
Caledonia, Ohio
Brian, is that with sea level el.?
Re: Reserection of my old W8 Bullet [Re: BigDog68Dart] #1296708
10/07/12 04:19 PM
10/07/12 04:19 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
im sure you will get you 8 sec time slip good luck
Re: Reserection of my old W8 Bullet [Re: Stroker Scamp] #1296709
10/07/12 09:47 PM
10/07/12 09:47 PM
Out West
Out West
Time to check the valve to piston clearance.
Plenty of valve to piston clearance, but radial is closer than expected.
Push rod is very close to port wall. Had to grind away just a little epoxy to gain some clearance.
Anyone see anything wrong with this picture? Had to move the upper pulley 6 teeth to get the cam degreed in. Why can they get it right on a $80 timing chain, but can't get it right with a $1300 belt drive?
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296710
10/08/12 01:54 AM
10/08/12 01:54 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Dang Brian hurry up with this thing you are killing me
Re: Reserection of my old W8 Bullet [Re: SB412DUSTER] #1296711
10/08/12 09:45 AM
10/08/12 09:45 AM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
I second that!!
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Reserection of my old W8 Bullet [Re: 440W8 Duster] #1296712
10/08/12 10:10 AM
10/08/12 10:10 AM
Out West
Out West
I guess I'm just to slow at the upload and narriation part. I have about 200 pictures.
Re: Reserection of my old W8 Bullet [Re: 408strokerdart] #1296713
10/08/12 10:14 AM
10/08/12 10:14 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Brian, just send them to me and I will post when you tell me too.. looks good, can't wait to see more..
Re: Reserection of my old W8 Bullet [Re: 70dusterjohn] #1296714
10/23/12 04:30 PM
10/23/12 04:30 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Need some more pictures to look at....
