i'm looking to rebuild my 71 383 over the winter months and am looking for some advice. i'd like a respectable street performer engine. i want to be able to get in a drive anywhere. the car has a 727 and a 3.55 rear gear. so, obviously i will be do an overbore and ring job, some new pistons, shooting for 10:1 compression and i want to run pump gas. i want to retain the stock look to the engine so i'm using cast iron manifolds, cast iron heads, cast iron intake. and either a 650 double pumper carb or a 750 vaccuum secondary carb.
now the real question is what to do with the heads. how critical is it to run a closed chamber these days, should i look for a 915 head? i am going to port and polish the heads and i'm thinking i may put the larger valves in. (stroker engine is not out of the question) also i'm thinking of running a solid cam maybe the mopar 528, i've had good luck with it in the past. so any comments, ideas, suggestions, etc, are all welcome.
