Intake question #1296242
09/03/12 03:12 PM
09/03/12 03:12 PM
duster408 Offline OP
I have a 71 duster with a 408 used for street and strip. What intake do I need? It has eddy heads and a comp 284H cam. I have 4.10 gears and a 3800 converter, I shift at 5400. Also is a 750 carb enough or too much?
Re: Intake question [Re: duster408] #1296243
09/03/12 03:25 PM
09/03/12 03:25 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
M-1 single plane or RPM air gap. 750 carb is the SMALLEST Id use.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Intake question [Re: 71yelladustr] #1296244
09/03/12 05:52 PM
09/03/12 05:52 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
You've got enough converter to run a single plane like an M1 or Weiand X-cellerator but I'll bet the car/combo will still et better using a performer RPM or RPM air gap intake. Your right on the cusp but the cam lift duration is fairly mild so I''d stick with the dual plane
WIZE
In Car:
Re: Intake question [Re: 71yelladustr] #1296245
09/03/12 09:05 PM
09/03/12 09:05 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Re: Intake question [Re: moparguy7074] #1296246
09/03/12 09:07 PM
09/03/12 09:07 PM
Renton Washington
Triple Threat Offline
Renton Washington
RPM air gap.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Intake question [Re: Triple Threat] #1296247
09/04/12 08:30 AM
09/04/12 08:30 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
RPM air gap.
I've been in the 10.8's with a 750dp and an Air-gap....not saying a 750 is optimal, but it will work.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
