Breaking Wheel Studs #1296211
09/03/12 01:34 PM
09/03/12 01:34 PM
SE Kansas
I
indytex96 Offline OP
I
SE Kansas
Hoping for some ideas, 1974 Charger stock wheel studs never been changed. I ran Cragar street stars for many years which were std 4.5 bolt pattern then changed to Greg Weld wheels that are a unilug pattern both took a mag type lugnut. So far the rears are fine but the front are not. Hit a small bump (very small) which immediately noticed something was wrong pulling over realized I had broke 2 studs and the rest were loose replaced the broken ones and no issues. Today no bumps 40 mph and same thing opposite side front What is happening? Is there a correct length stud for mags as I only 3/4 to 1" of threads in nut or is it a wheel issue. I used a torque wrench when I installed and wheels were balanced w/ no issues. Sorry for being long winded, but wanted to give as much info as possible. Thanks
Re: Breaking Wheel Studs [Re: indytex96] #1296212
09/03/12 01:51 PM
09/03/12 01:51 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Pretty sure you have either the wrong style lug nut or too short of studs, maybe both?
picture would be good
Re: Breaking Wheel Studs [Re: Challenger 1] #1296213
09/03/12 02:22 PM
09/03/12 02:22 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ill say you have the wrong lugs.You must use his lugs and washers.The lugs come with 2 sets of washers.I believe the offsets are for Mopar pattern.I have a set that I ran for 3 years at least.Never had a problem.Rocky
Chrysler Firepower
Re: Breaking Wheel Studs [Re: indytex96] #1296214
09/03/12 02:41 PM
09/03/12 02:41 PM
IMGTX Offline
IMGTX  Offline
On many rims I have used they require both the offset washers and a Lug nut with a shank on it. You are not using Acorn style nuts are you?
Re: Breaking Wheel Studs [Re: therocks] #1296215
09/03/12 02:51 PM
09/03/12 02:51 PM
SE Kansas
I
I
SE Kansas
I put these on over a year ago with few miles on them and bought them used which came with gm style lugs and washers. If I recall correctly I purchased the lugs and correct washers from them directly. The lugs look like normal mag style shank with the washers being offset slightly not quite as aggressive as normal unilug washers. I do know the stud is very close to the inside edge of the wheel hub to the point I cannot fit a normal lug wrench in there using a socket is a must. Is this how your fit?
Re: Breaking Wheel Studs [Re: indytex96] #1296216
09/03/12 03:04 PM
09/03/12 03:04 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Since the others were loose, I'd say you have a fit problem or they loosened up.
Pull the wheel and check the depth of the lug nut from the back. It must not extend to the inner edge of the wheel or it will not tighten. There should be a bit of clearance. Also clean and check the studs. Many have shoulders at the base. The lug nuts must not reach this point and bottom out on the stud shoulder or again it will not fully tighten the wheel!
After all is checked and any problems fixed, install and torque the wheels. Drive a bit to get everything seated and warm. Recheck torque. Do it again (cold, warm, check) a couple times to see if they loosen up.
Re: Breaking Wheel Studs [Re: indytex96] #1296217
09/03/12 03:07 PM
09/03/12 03:07 PM
CrazyD Offline
CrazyD  Offline
Is the shank of the lug nut bottoming out before tighting against the wheel hub? Try running down the nut whithout the wheel on and see. Did the studs shear at the drum or rotor hub face?
Re: Breaking Wheel Studs [Re: CrazyD] #1296218
09/03/12 03:41 PM
09/03/12 03:41 PM
SE Kansas
I
I
SE Kansas
Sheared at the rotors hub face.
Re: Breaking Wheel Studs [Re: indytex96] #1296219
09/03/12 06:35 PM
09/03/12 06:35 PM
CrazyD Offline
CrazyD  Offline
if you search Google with:
"Greg Weld" broke stud
it seems you're not the only one...
Re: Breaking Wheel Studs [Re: indytex96] #1296220
09/03/12 06:52 PM
09/03/12 06:52 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
This is a common problem with sheetmetal wheels.
The soft, springy wheel centers crush before the studs can be tightened adequately.
Re: Breaking Wheel Studs [Re: DoctorDiff] #1296221
09/03/12 07:21 PM
09/03/12 07:21 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks for the heads up. Is there anything that can be done to fix the problem?
Wow I was gonna suggest cheap wheels in my first post be decided to stay positive...
Re: Breaking Wheel Studs [Re: Challenger 1] #1296222
09/04/12 12:28 AM
09/04/12 12:28 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The only thing you can do is lube the threads and check the torque often.
Most of the time, when you hear of guys shearing 1/2" wheel studs, they are running Weld wheels.
A 1 1/2" thick stack of aluminum sheet metal does not make the best wheel center.
