Fuel Stain On Intake #1296205
09/03/12 01:31 PM
09/03/12 01:31 PM
dusterjp Offline OP
dusterjp  Offline OP
Does anyone have a good solution for cleaning a fuel stain on an aluminum intake. I don't want to take it off if I don't have to.
Re: Fuel Stain On Intake [Re: dusterjp] #1296206
09/03/12 02:04 PM
09/03/12 02:04 PM
dogdays Offline
dogdays  Offline
Simple green and a toothbrush?
R.
Re: Fuel Stain On Intake [Re: dogdays] #1296207
09/03/12 02:27 PM
09/03/12 02:27 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
carb cleaner and a toothbrush?
R.
fixed
Re: Fuel Stain On Intake [Re: mikemee1331] #1296208
09/03/12 03:52 PM
09/03/12 03:52 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
carb cleaner and paper towels
The carb cleaner will dissolve the stains without the toothbrush, but you need the paper towels to soak up the stain and actually remove it.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Fuel Stain On Intake [Re: HemiRick] #1296209
09/03/12 06:31 PM
09/03/12 06:31 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
if you use the tooth brush be prepared to clean the whole intake,itll be super clean compared to the rest that you THINK is clean.
Re: Fuel Stain On Intake [Re: bonefish] #1296210
09/03/12 07:36 PM
09/03/12 07:36 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
open pore aluminimum Mag wheel cleaner.. Spray it on, hose it off. Dont fill the dist with water..
I am truckless..
