'70 Hemi Cuda identifying features #1295881
09/02/12 07:31 PM
09/02/12 07:31 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Hello everyone,
I recently looked at a '70 Hemi Cuda project car but I have a few questions regarding identifying it as a legit Hemi car. Everything looks correct, but I want to make sure. I am a B-body guy and E-body's are something new to me. The car was a race car almost since day one so a bunch of stuff is missing that would help identify it. It is a 4 speed car. Here is what I saw:
'70 Cuda with correct VIN tag, door sticker, cowl number, and radiator support number. I did not get a chance to check the number on the trunk lip.
Hemi k-member with skid plate.
Dana 60
"Hemi fender" tag but I have not seen the actual "fender tag" although he states he has it.
What was not there because it was removed early in its life:
3/8" fuel line, 3 spd wiper motor, and correct radiator.
Does anyone have a picture of the correct E-body pinion snubber plate and the torque boxes. I think they are different than the B-body stuff.
It is a manual steering car. The car also has manual drum brakes. Did they make Hemi Cudas with 4 wheel drum brakes?
That's about it. There seems to be lots of paperwork with the car. I just want to have all the information I need when I go back to look at the car.
Thanks.
Stan
Re: '70 Hemi Cuda identifying features [Re: HemiStan] #1295882
09/02/12 07:48 PM
09/02/12 07:48 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
E-bodies do not have them.
B11 - HD drum brakes standard. Power disc brakes optional.
If you want to email with the VIN I can check to see if I know anything about it for you.
Re: '70 Hemi Cuda identifying features [Re: Alaskan_TA] #1295883
09/03/12 05:23 AM
09/03/12 05:23 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Barry,
I will see if I can get a photo of the VIN as well as the fender tag over the next couple of days.
Thanks.
Stan
Re: '70 Hemi Cuda identifying features [Re: HemiStan] #1295884
09/03/12 07:44 AM
09/03/12 07:44 AM
western australia
1cuda Offline
1cuda  Offline
western australia
since your taking pics-take one of the shaker cable hole on the firewall-see if it`s got the thick spacers on the trans mount and the spacers for the 15 inch wheels on the control arm rubber snubber things.
also the trunk floor spare tire hold down rod. some of these items are not unique to hemicudas but if something isn`t right it will open a can of something...it shouldn`t have wheel arch mouldings and the front fenders were modified on the upper wheelarch-that`s why it`s got a hemi fender tag. more than likely made later in the 70 year-i`m sure someone will have an approximate date when they started adding the extra tag i think it was about feb march 1970.
make sure you get the numbers from the engine and trans too.
all the best
frank
Re: '70 Hemi Cuda identifying features [Re: 1cuda] #1295885
09/03/12 05:28 PM
09/03/12 05:28 PM
California
biggE Offline
biggE  Offline
California
Early cars did not have the "hemi fender" tag and they did have the wheel lip mouldings.
Re: '70 Hemi Cuda identifying features [Re: biggE] #1295886
09/03/12 07:52 PM
09/03/12 07:52 PM
western australia
1cuda Offline
1cuda  Offline
western australia
this is the first i`ve heard of wheel lip mouldings on a hemicuda-anyone have any buildsheets with wheel lip moulds on them. i`m not saying it couldn`t happen but i`ve never come across one.
all the best
frank.
Re: '70 Hemi Cuda identifying features [Re: 1cuda] #1295887
09/03/12 08:02 PM
09/03/12 08:02 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yes & it is true.
Re: '70 Hemi Cuda identifying features [Re: Alaskan_TA] #1295888
09/03/12 08:40 PM
09/03/12 08:40 PM
western australia
1cuda Offline
1cuda  Offline
western australia
i believe you. thanx for that.
frank.
Re: '70 Hemi Cuda identifying features [Re: 1cuda] #1295889
09/04/12 08:05 PM
09/04/12 08:05 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Barry,
I sent you a picture of the door VIN decal.
Thanks.
Stan
Re: '70 Hemi Cuda identifying features [Re: HemiStan] #1295890
09/05/12 08:24 AM
09/05/12 08:24 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Should all Hemi Cudas have come with 150 mph speedometers? This one has a 120 mph speedometer.
Stan
Re: '70 Hemi Cuda identifying features [Re: HemiStan] #1295891
09/05/12 09:40 AM
09/05/12 09:40 AM
western australia
1cuda Offline
1cuda  Offline
western australia
i know of a 70 hemicuda with what is known as a standard dash not the ralley dash.
if the car your looking at has a standard dash with no tach check where the roadlamp switch is located on the dash. it also shouldn`t have n85 on the tag for tachometer.
all the best
frank.
Re: '70 Hemi Cuda identifying features [Re: 1cuda] #1295892
09/05/12 09:43 AM
09/05/12 09:43 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The standard dash was a standard item on all 70 Cuda models, Hemi or otherwise. The Rallye gauge package was an option. I don't have an exact count (nor do any solid numbers exist) but it seems I've seen more original Hemi Cudas with standard gauges than with Rallyes, it was common.
Re: '70 Hemi Cuda identifying features [Re: ScottSmith_Harms] #1295893
09/05/12 09:53 AM
09/05/12 09:53 AM
western australia
1cuda Offline
1cuda  Offline
western australia
i don`t want to change the thread but does a standard dash accept a variable speed wiper switch? i`m sure i tried to put one into a standard dash once and had to file something to make it fit. shaker cars couldn`t use a two speed wiper so what does the hemicuda have as a wiper setup?
all the best
frank
Re: '70 Hemi Cuda identifying features [Re: 1cuda] #1295894
09/06/12 01:09 AM
09/06/12 01:09 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
....Are you guys saying all Hemi Cudas had wheel lip moldings or are you saying it was an option??
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: '70 Hemi Cuda identifying features [Re: Troy] #1295895
09/06/12 06:22 AM
09/06/12 06:22 AM
western australia
1cuda Offline
1cuda  Offline
western australia
as alaskan t/a pointed out (and i didn`t know this) but some had wheel lip mouldings and i believe most did not have wheel lip mouldings-if the one in question had a hemi fender tag i believe it didn`t have wheel lip mouldings. the front fenders were different to standard fenders and the wheel lip mouldings couldn`t attach in the upper middle area.
all the best
frank.
Re: '70 Hemi Cuda identifying features [Re: Troy] #1295896
09/06/12 10:29 AM
09/06/12 10:29 AM
California
biggE Offline
biggE  Offline
California
All early hemicudas had wheel lip mouldings through at least mid October 1969 production. I assume that they discontinued them because of labor cost. Each front moulding had to have the center portion hand trimmed for tire clearance. I assume they used a band saw or something like that because the trimmed portion was not finnished very nicely.
Re: '70 Hemi Cuda identifying features [Re: biggE] #1295897
09/06/12 01:18 PM
09/06/12 01:18 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
There is a thread here on Moparts from the actual guy that folded those fenders over. I believe at Creative Industries??.
I think/hope it is archived here.
Do the wheel lip molding scenarios also apply to all 15" rim cars like 340 'Cudas? If so, do that have a molding vs non molding cutoff rough date/timeline?
Re: '70 Hemi Cuda identifying features [Re: autoxcuda] #1295898
09/06/12 03:26 PM
09/06/12 03:26 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
The 340/383/440 cudas used the E60-15 tires, so they didn't need the lip mods.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: '70 Hemi Cuda identifying features [Re: 1cuda] #1295899
09/13/12 02:14 PM
09/13/12 02:14 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
all the best
frank.
Most if not all Hemi Cudas had wheel lip mouldings until the factory hemi fender was ready.(March-April 70). All were hand cut to match the modified fender and reinstalled.NO hemi-fender tag on the Creative modified fender cars.
Once again NO Hemi-Challengers should have wheel lips mouldings.Mouldings were not wide enough to cut and reinstall.They were removed along with the front inner fender brace and discarded.Yes,they came installed on the car.
Re: '70 Hemi Cuda identifying features [Re: mike s] #1295900
09/29/12 03:59 PM
09/29/12 03:59 PM
Bristol, CT
RalphsRapidTrnst Offline
Bristol, CT
My Hemicuda build date Oct 30 1969 has no hemi fender tag (Should not). Has its "original" Wheel Lip moldings that never were modified (should of been). My fenders are modified (All Original sheet metal).
I believe that all 1971 HemiCuda's do not have / never came with wheel lip moldings. I have yet to see an original build sheet listing wheel lip moldings on a 1971 Hemicuda.
A Collection Of All Things Chrysler
www.RalphsRapidTransit.com
Stock Appearing MuscleCar Racing
www.SuperCarRaces.com
