Door Mirror Nut Inserts - painting question #1295709
09/02/12 02:58 PM
09/02/12 02:58 PM
california
Mr D21 Offline OP
Mr D21  Offline OP
california
Prior to painting is it recommended to remove the screw inserts that hold the mirrors to the doors? These inserts are crimped on the doors.
If so, what is the recommended way to remove without damaging the hole size ?
Re: Door Mirror Nut Inserts - painting question [Re: Mr D21] #1295710
09/02/12 03:45 PM
09/02/12 03:45 PM
CT
1932chrysler Offline
CT
Don't remove them
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
Re: Door Mirror Nut Inserts - painting question [Re: 1932chrysler] #1295711
09/02/12 10:05 PM
09/02/12 10:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Run a bolt up from inside, then unscrew it after paint. Or, use a plastic/rubber plug from the inside. Or, just chase the threads with a tap after paint.
Re: Door Mirror Nut Inserts - painting question [Re: topside] #1295712
09/02/12 10:15 PM
09/02/12 10:15 PM
california
Mr D21 Offline OP
Mr D21  Offline OP
california
Im not worried about getting paint in the threads as I have old screws I can leave in place. But since the car is apart, whats 4 more inserts if it will benefit the overall paint job in that area.
Are they easy to remove ?
Any risk to the door holes ?
Re: Door Mirror Nut Inserts - painting question [Re: Mr D21] #1295713
09/02/12 11:19 PM
09/02/12 11:19 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
They are not easy to remove but if you feel the need I'd use a die grinder & cut the head off... Personally I'd leave them in...
Re: Door Mirror Nut Inserts - painting question [Re: 1_WILD_RT] #1295714
09/04/12 08:38 AM
09/04/12 08:38 AM
London, England
Gavin Offline
Gavin  Offline
London, England
You can remove them fairly easily (but carefully!) by using a drill of the correct size. It will take the head of the insert off and the back of the insert will fall out. Ideally you want to be careful not to let the drill bite and spin the head which may scuff the paint, but this can be done and if you are repainting not an issue. But I agree, no reason to remove if they are in working condition. (I needed to do this because one was incorrectly positioned...don't ask...)
