TQ Question #129534
09/29/08 02:43 PM
09/29/08 02:43 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I'm rebuilding a TQ. Question is which rubber seal goes in the bottom of the plastic peice that keeps fuel from leaking into the intake? I have three different ones in the kit. One set has ribs on it another is a little thicker and no ribs and the third is an "O" ring. Which set should I use?
Re: TQ Question [Re: JonC] #129535
09/29/08 06:48 PM
09/29/08 06:48 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Anyone? I'd like to put this together tonight. Maybe I didn't explain it right?
Re: TQ Question [Re: JonC] #129536
09/29/08 08:55 PM
09/29/08 08:55 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
The ones with the "ribs"
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: TQ Question [Re: 69L78Nova] #129537
09/29/08 09:11 PM
09/29/08 09:11 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
BTW Did you epoxy the bottom of the fuel wells?...
Re: TQ Question [Re: 1_WILD_RT] #129538
09/30/08 09:18 AM
09/30/08 09:18 AM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I did not epoxy the wells, however I did fill them with WD 40 and let sit overnight and no signs of leakage.
Re: TQ Question [Re: JonC] #129539
09/30/08 10:03 AM
09/30/08 10:03 AM
Midland, Tx
rjones Offline
rjones  Offline
Midland, Tx
This is a good thread and after reading it I realize I may have a TQ that has a leaking fuel well. What I notice is the engine is slightly fuel loaded on restarts after sitting for about 15 to 30 minutes. Also, the carb will be empty of fuel if I let sit for more than 2 days. I am gonna check it.
Thanks,
Roger
Re: TQ Question [Re: rjones] #129540
09/30/08 11:51 AM
09/30/08 11:51 AM
Midland, Tx
rjones Offline
rjones  Offline
Midland, Tx
What type of epoxy do you use on these?
Roger
Re: TQ Question [Re: rjones] #129541
09/30/08 01:37 PM
09/30/08 01:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've used JB Weld for years with good results, I use a dremel with a small burr to expose clean material then mix up the JB Weld & apply a thin coating completely around the well...
Re: TQ Question [Re: JonC] #129542
09/30/08 08:38 PM
09/30/08 08:38 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Just remember, WD-40 is thicker than gasoline
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: TQ Question [Re: 69L78Nova] #129543
09/30/08 08:53 PM
09/30/08 08:53 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: TQ Question [Re: rjones] #129544
10/01/08 01:58 AM
10/01/08 01:58 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
Thanks,
Roger
You have one or both jet wells leaking. Those are the exact symptons you described. Do like 1 Wild RT says to fix the problem. I always used the ribbed condoms oops I mean o-rings too.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: TQ Question [Re: JonC] #129545
10/01/08 08:13 AM
10/01/08 08:13 AM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Well, I put it together and it works good. All I have to do now is adjust the air valve. I had the same symtoms described above and now cold or hot all I do is touch the key and it starts with no choke.
