Re: need to slow it down
[Re: savoyracer]
#1295355
09/01/12 09:00 PM
09/01/12 09:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Car runs 9.60's and I want to get it above 10.00's.....buddy of mine has a similar et, and he disconnected the secondaries on the carb, dropped him into the 10.20's. that is what I would like to do. So, my question is will that make the car run lean??
I slowed my car with a mech throttle stop... it goes about 1/3 throttle then I adjust the launch rpm and the shift point... you would need to take way too much timing out so I wouldnt even look at that... with the mech stop it opens both blades some so you get equal distribution ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1295356
09/02/12 12:59 AM
09/02/12 12:59 AM
Posts: 446 oregon
savoyracer
oregon
...............When you say a mechanical throttle stop, you mean that you are just blocking the throttle linkage from opening up more than a third of the way?........and i would not need to adjust the timing?
[Re: savoyracer]
#1295357
09/02/12 01:23 AM
09/02/12 01:23 AM
MR_P_BODY
Correct.... I put a short pretty stiff spring on the throttle cable to the carb also... if you have the type of cable that is adjustable you can slide it forward so you dont break the cable(mine isnt adjustable) and no I dont touch the timing.... I was doing this so I could run multiple classes with a quick and easy way to change over..... this is the throttle stop I made to fit my dom ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1295359
09/02/12 10:37 AM
09/02/12 10:37 AM
Posts: 446 oregon
savoyracer
oregon
...............Looks like that will work for me also, going to give it a try, Thank You ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Mr.Yuck]
#1295360
09/02/12 10:41 AM
09/02/12 10:41 AM
Posts: 446 oregon
savoyracer
oregon
Could you short shift it or take some throttle out of the car?
.........could not get anything consistent with the short shift, going to try Mr P's idea about the throttle stop
[Re: savoyracer]
#1295361
09/02/12 10:46 AM
09/02/12 10:46 AM
MR_P_BODY
Doing it the way I was I ran 8 passes in a row at 10.00 with a total variance of .008 for the day... I was slowing it down to run the 10.0 class... then I would pull off the stop and run S/P... would take me about 2 minutes to change over ![](/ubbthreads/images/graemlins/wave.gif)
