Page 3 of 4 1 2 3 4
Re: Hemi Progress, or Lack thereof.......... [Re: CrAzYMoPaRGuY] #1295289
09/23/12 08:11 PM
09/23/12 08:11 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Lookin' good....
Re: Hemi Progress, or Lack thereof.......... [Re: jim sciortino] #1295290
09/24/12 05:49 PM
09/24/12 05:49 PM
Taxes & Virus's R-US, NY
Dragula Online content OP
Dragula  Online Content OP
Its in and running. I need to tidy up a bunch of stuff, but we will make TNT for Friday...
Re: Hemi Progress, or Lack thereof.......... [Re: Dragula] #1295291
09/26/12 09:41 PM
09/26/12 09:41 PM
Cam break in tomorrow, change the oil, put a different throttle cable on it, put the hood on, fix the water pump and fan wiring. Need a #2 wire from the Fire Core guy. Seems he forgot one. But had it running and got the timing semi close....And that is a new Pro Systems carb.
Re: Hemi Progress, or Lack thereof.......... [Re: Dragula] #1295292
09/26/12 10:40 PM
09/26/12 10:40 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
That carb looks tiny on that motor. How many CFM is it?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Hemi Progress, or Lack thereof.......... [Re: DusterDave] #1295293
09/26/12 11:33 PM
09/26/12 11:33 PM
1000cfm...
Re: Hemi Progress, or Lack thereof.......... [Re: Dragula] #1295294
09/27/12 02:10 AM
09/27/12 02:10 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Congrats on the progress!
Re: Hemi Progress, or Lack thereof.......... [Re: Dragula] #1295295
09/27/12 04:19 AM
09/27/12 04:19 AM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
Why no dommy? Thats a 605 correct?
Re: Hemi Progress, or Lack thereof.......... [Re: Abodyjohn88] #1295296
09/27/12 06:32 AM
09/27/12 06:32 AM
I wish it was a 605...Its a 484.
Wanted an SV1, they recommended a dominator based 4150...I went with their recomendation.
Re: Hemi Progress, or Lack thereof.......... [Re: Dragula] #1295297
09/27/12 07:20 AM
09/27/12 07:20 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
The 1000cfm should be more than enough carb for that motor. Dave
Re: Hemi Progress, or Lack thereof.......... [Re: quickd100] #1295298
09/27/12 07:34 AM
09/27/12 07:34 AM
Same thing according to Pro systems as well, but I miss my injection. That was 2100cfm and I ran that on a 431 hemi all the way up to my 484...if EFi becomes legal, its going right back on and I will upgrade to the latest FAST computer. Right now I am leaning toward having BGR make me a tented top plate for the tunnel ram, and running the carb that way if it will clear the hood, not sure yet.
Re: Hemi Progress, or Lack thereof.......... [Re: Dragula] #1295299
09/30/12 09:54 PM
09/30/12 09:54 PM
Well, we broke the cam in on Thursday, took the car to the local 1/8th mile on Friday, and due to rain where the 1/4 track was we had no choice...All in all, no real issues other than it ate an alternator belt....
And the ProSyetems carb looks small, but its a 4150 based with all Dominator parts. So it has the 50cc pumps, the Dominator fuel blocks, and is jetted the same as one..I went with what he recommended instead of what I wanted...for now.
7.0 at 97mph on street tires pump gas, and street gears leaving real easy and shifting at 6300..Was still spinning thru low though, and I couldn't even get it into 3rd in the 1/8th with street gears, Dr. Diff is fixing me up this week...And we are going back this Friday..Engine still feels tight, but the idle came around and the plugs were looking real good, and on the last pass the 60ft got a lot better when we made a shock adjustment.
Re: Hemi Progress, or Lack thereof.......... [Re: Dragula] #1295300
09/30/12 10:20 PM
09/30/12 10:20 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Lookin' good Randy, it'll drop a bunch after you get everything dialed in. The manifold looks alot better on your motor.
Got rid of the chassis shake on mine, now I need a convertor that stalls @4800 for mine. Also have to still get the chassis dialed in. I think high 9's are a possibility. Dave
Re: Hemi Progress, or Lack thereof.......... [Re: quickd100] #1295301
09/30/12 10:44 PM
09/30/12 10:44 PM
I might have modified your intake slightly....Ported it further, removed all the logo, had it almost ready to polish and ran out of time and thru some paint on it. Nother week, and it would have been shiney...
And I would think if your drive shaft and the rest are up to holding that monster, 9's are a given, but I would bet you will still find a few things that aren't. Wish mine would go 9.90's, maybe down the road I will move into a 572 or somthing. For now, the goal is 10.50's depending on the final weight. The 4.56's should net me 10.80's or so. THe last pass in the 1/8th it was on a real good run, probably a 6.90 somthing, but somehow I went from 1st-3rd and lost some ET...
Re: Hemi Progress, or Lack thereof.......... [Re: Dragula] #1295302
10/01/12 02:06 AM
10/01/12 02:06 AM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
I gotcha... I get confused with your guys trucks. That 484 looks sweeeet!
Re: Hemi Progress, or Lack thereof.......... [Re: Abodyjohn88] #1295303
10/01/12 07:37 AM
10/01/12 07:37 AM
Hopefully new gear puts us in the 6.8's in the 1/8th and we need to dial in the timming and probably the squirter shot. More of the timming though. I should have had the damper rebuilt before we ran it. There is a little concern on whether its accurate or not.
Re: Hemi Progress, or Lack thereof.......... [Re: Dragula] #1295304
10/01/12 08:00 AM
10/01/12 08:00 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I'd still have to change that carb! looks like one of them shrunken head people...
Mopar Performance
Re: Hemi Progress, or Lack thereof.......... [Re: moparniac] #1295305
10/02/12 11:20 PM
10/02/12 11:20 PM
Yeah, but it sure is shiney....And it runs really well so far. Car is in getting the rear changed to 4.56's, so hopefully we hit my ET goal
Re: Hemi Progress, or Lack thereof.......... [Re: Dragula] #1295306
10/02/12 11:34 PM
10/02/12 11:34 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What did you end up with for push rods??Did you use restrictors?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi Progress, or Lack thereof.......... [Re: Dragula] #1295307
10/03/12 06:11 AM
10/03/12 06:11 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
What is your ET goal?
Re: Hemi Progress, or Lack thereof.......... [Re: hemi-itis] #1295308
10/03/12 07:41 AM
10/03/12 07:41 AM
To make a long story short with all our discussions with Indy and World, there is a bunch of confusion putting Indy heads on a World Block on our end and some things we did not know.
For now, we stayed with the push rods we had and kept the restrictors in the block as we did not want to pull it all apart again. It was already in the car.
The way the system is supposed to work, is there should be no restrictors in the block, as Indy has convienently relocated them into the heads. The oil feed holes in the heads are tapped to accept restrictors while bolted to the block, a very nice feature we were un-aware of.
Luckily, the restrictor size we used worked with our oil pump once the system was fully primed, and we finally got oil up top. We primed it with a drill motor. It took longer than expected to get the oil out the intakes, but all is good right now.
So anyone running a World block and Indy Hemi heads, should take note of that feature.
Page 3 of 4 1 2 3 4
