Fuel Pressure Question
#1295022
09/01/12 11:51 AM
09/01/12 11:51 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I have a mechanical fuel pressure gage in line just before the carb. I am used to seeing the fuel gage showing pressure for several minutes (15+?) after I shut down the car. This morning I noticed that the fuel gage is dropping to zero after 15 seconds or so after the car is shut down. When the car was running, it was showing the proper 6+psi at idle, but I shut it down twice this morning while watching the fuel pressure and it dropped to 0 both times. Do you guys see the fuel pressure drop this quick after you shut your cars down? This is not typical for mine, so I am wondering if I am seeing the beginnings of a fuel pump (Carter mechanical) issue. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Fuel Pressure Question
[Re: bb489ss]
#1295024
09/01/12 08:40 PM
09/01/12 08:40 PM
YO7_A66
Indiana
Thanks for your reply. I am just worried because I usually have to wait an hour or so or just crack open the carb to releive the pressure after a drive if I am making a tuning change. Today the pressure fell off as soon and I turned off the car and walked around to the engine to look at the gage. I also had some lean issues on my last drive that I could not explain. If the pump is going south, then my tuning issues would have an explanation. If not, then I need to keep searching.
[Re: RapidRobert]
#1295029
09/01/12 11:15 PM
09/01/12 11:15 PM
Posts: 3,916 usa
lewtot184
usa
That's a good question as you'd sure hate to have fuel leaking into the crankcase. A leaking needle/seat wouldn't be as bad but would need to be addressed and this DID happen all of a sudden. I think I'd toss on another pump even a cheap parts house airtex just to see if it goes back to holding pressure
i've had those pumps apart before. i think it would be difficult to get fuel in the crankcase with one. they have a relief hole in the top and the diaphragm has a seal at the top that the pressure spring holds in place.
[Re: RapidRobert]
#1295031
09/02/12 12:03 AM
09/02/12 12:03 AM
YO7_A66
Indiana
The unit that I have is one of the "sealed" (cheaper) units. I can not open it up to repair it. It is about 3 years old and it has me worried since it stopped holding pressure after shut down and I had the weird lean issues on the last drive. Thank you all!! EDIT: I just checked and both bowls still show fuel in the sight glasses. It appears not to have any internal carb leaks. The unit is a Carter M6866.
[Re: YO7_A66]
#1295032
09/02/12 10:20 AM
09/02/12 10:20 AM
Posts: 3,916 usa
lewtot184
usa
i don't care for those 2 valve pumps for performance.
[Re: lewtot184]
#1295033
09/02/12 11:18 AM
09/02/12 11:18 AM
YO7_A66
Indiana
Thank you for your reply. I am currently shopping for a new one and I have started a new thread on suggestions. Thanks
