SO whats the REAL numbers?? Your guess vs Happy Dyno #1294715
08/31/12 07:16 PM
08/31/12 07:16 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I finally have my engine back for my Procharger Build
I had the engine on the dyno to set the rings and check for any problems.
It was Dyno tested Naturally Aspirated with a 850 DP
Here are the specs
500 inch mopar
8.6 compression
Indy EZ heads flowing about 290-300 at 500 (prepped by Dwayne Porter)
Solid Roller Cam
257, 267 at 50
650 lift on a 112
Was the Dyno Happy or?
Whats your REAL HP/TQ Guess?
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Kam*Kuda] #1294716
08/31/12 08:52 PM
08/31/12 08:52 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
That would look like a 600 hp build with 10.5 comp. With the cam and carb, I would still guess around that although when the pro charger goes on, all bets are off!
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Lee446] #1294717
08/31/12 09:03 PM
08/31/12 09:03 PM
ont,canada
mopartuner Offline
mopartuner  Offline
ont,canada
610 is my guess
410 pump gas solis flat tappet cam 10.95 so far
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Kam*Kuda] #1294718
08/31/12 09:08 PM
08/31/12 09:08 PM
Dana Point, CA
Fast Yeti Offline
Fast Yeti  Offline
Dana Point, CA
525hp
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Kam*Kuda] #1294719
08/31/12 10:00 PM
08/31/12 10:00 PM
gregsdart Offline
gregsdart  Offline
600+ for sure.
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Kam*Kuda] #1294720
08/31/12 10:11 PM
08/31/12 10:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
As its sets right now 535hp
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Kam*Kuda] #1294721
08/31/12 10:37 PM
08/31/12 10:37 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The low CR is tossing me a curve. Not really sure the impact of that. I'll say 615 hp.
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: BSB67] #1294722
08/31/12 10:40 PM
08/31/12 10:40 PM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
Ive heard that 1 full point of compression is worth about 40 horsepower...
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Abodyjohn88] #1294723
08/31/12 10:43 PM
08/31/12 10:43 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
then I'm probably too high
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: BSB67] #1294724
08/31/12 11:08 PM
08/31/12 11:08 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Heres the dish B ut they were coated afterwards
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: gregsdart] #1294725
08/31/12 11:14 PM
08/31/12 11:14 PM
gregsdart Offline
gregsdart  Offline
600+ for sure.
I just spotted the 8.6 to 1 compression, drop 25 hp. 575
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Kam*Kuda] #1294726
08/31/12 11:20 PM
08/31/12 11:20 PM
Idaho
LaRoy Engines Offline
Idaho
With those heads by Dwayne, even driving the water pump with the crank and the 8.6:1 compression, I would expect 630 lb-ft @ 4700 and 640 hp @ 6100.
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: LaRoy Engines] #1294727
08/31/12 11:24 PM
08/31/12 11:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With a 850 carb on a 500"... you guys are optimistic.... JMO
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: gregsdart] #1294728
08/31/12 11:29 PM
08/31/12 11:29 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
My 8.97:1 493 with OOTB Eddies and an MP509 did 500. you've got a little less CR but a little more cylinder head and more cam so I'll guess 560ish N/A.
Kevin
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Twostick] #1294729
09/01/12 12:03 AM
09/01/12 12:03 AM
Arizona
Chris'sBarracuda Offline
Arizona
The only way to tell if it's happy or not is to take it down the track..
MPH is the true tell.
You've got guesses from 500hp-640hp..
How would you even know if it was happy or not with a 140hp difference in guesses..
Anyway, if there are previous engines that have dynoed there and backed up the MPH from the dyno, you should be satisfied..
If not...
Chris..
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Chris'sBarracuda] #1294730
09/01/12 01:25 AM
09/01/12 01:25 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow thats real close to my 493. I also use EZ heads from Dwayne Porter. I have 10.6 comp with dished pistons but not that much as my pistons have a flat for quench. I use a sold flat tappet cam by Dwayne also thats .592 lift but I use 1.6 rockers.
What intake is that ?? I use the Indy dual plane intake with an 850 DP. My guess is about 590 hp. Good luck , Ron
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Chris'sBarracuda] #1294731
09/01/12 01:39 AM
09/01/12 01:39 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
FYI it is a Victor EFI Intake. Dwayne did a little bit of work to it as well.
1654.5 Mustang
1955 Land Rover
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Kam*Kuda] #1294732
09/01/12 09:32 AM
09/01/12 09:32 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I can't see why it would not make 630 to 645 as is??
610 foot lbs
At 11.6 to 1 would be a 700+ motor
So what did it make?
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Kam*Kuda] #1294733
09/01/12 09:47 AM
09/01/12 09:47 AM
NC
440Jim Offline
440Jim  Offline
NC
What were the dyno numbers?
Re: SO whats the REAL numbers?? Your guess vs Happy Dyno [Re: Kam*Kuda] #1294734
09/01/12 11:39 AM
09/01/12 11:39 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Here are the specs
500 inch mopar
8.6 compression
Solid Roller Cam
257, 267 at 50
650 lift on a 112
Nice valvecovers
That's a 550-570hp combo on Dwaynes dyno so i'm sure it made more somewhere else
Glad it got broken in with no issues and what i really want to see is how much it makes with 12lbs of booost
Ron
