Re: SO whats the REAL numbers?? Your guess vs Happy Dyno
[Re: Twostick]
#1294729
09/01/12 12:03 AM
09/01/12 12:03 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
The only way to tell if it's happy or not is to take it down the track.. MPH is the true tell. You've got guesses from 500hp-640hp.. How would you even know if it was happy or not with a 140hp difference in guesses.. Anyway, if there are previous engines that have dynoed there and backed up the MPH from the dyno, you should be satisfied.. If not... Chris..
[Re: Chris'sBarracuda]
#1294730
09/01/12 01:25 AM
09/01/12 01:25 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Wow thats real close to my 493. I also use EZ heads from Dwayne Porter. I have 10.6 comp with dished pistons but not that much as my pistons have a flat for quench. I use a sold flat tappet cam by Dwayne also thats .592 lift but I use 1.6 rockers. What intake is that ?? I use the Indy dual plane intake with an 850 DP. My guess is about 590 hp. Good luck , Ron
[Re: Kam*Kuda]
#1294732
09/01/12 09:32 AM
09/01/12 09:32 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I can't see why it would not make 630 to 645 as is?? 610 foot lbs At 11.6 to 1 would be a 700+ motor So what did it make?
[Re: Kam*Kuda]
#1294733
09/01/12 09:47 AM
09/01/12 09:47 AM
Posts: 16,928 NC
440Jim
NC
Was the Dyno Happy or?
What were the dyno numbers?
[Re: Kam*Kuda]
#1294734
09/01/12 11:39 AM
09/01/12 11:39 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
I finally have my engine back for my Procharger Build
I had the engine on the dyno to set the rings and check for any problems.
It was Dyno tested Naturally Aspirated with a 850 DP
Here are the specs
500 inch mopar 8.6 compression Indy EZ heads flowing about 290-300 at 500 (prepped by Dwayne Porter) Solid Roller Cam 257, 267 at 50 650 lift on a 112
Was the Dyno Happy or? Whats your REAL HP/TQ Guess?
Nice valvecovers
That's a 550-570hp combo on Dwaynes dyno so i'm sure it made more somewhere else
Glad it got broken in with no issues and what i really want to see is how much it makes with 12lbs of booost
Ron
