Brake dragging when hot...
#1294633
08/31/12 03:44 PM
08/31/12 03:44 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
'01 Durango. Front discs, rear drums. Right front brake dragging bad when hot. Worse after brake application. After driving a bit (presumably some cooling is occurring), it seems not to drag as much. Left front is fine - no dragging. This morning in garage with front end off the ground - overnight cool, both wheels turn freely.
Several months ago, replaced rubber hoses with Goodridge braided stainless steel hoses, properly bled, no dragging, and worked fine. Could that have anything to do with it?
Maybe the caliper is hanging up when hot?
Wheel's off now, nothing obvious jumping out.
As always, TIA. -Marq
Re: Brake dragging when hot...
[Re: MoparMarq]
#1294637
08/31/12 04:23 PM
08/31/12 04:23 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
They can be rebuilt. It's just a seal and a boot. Compressed air gets it apart. Hone the cylinder and install the new parts. Tons cheaper.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1294640
08/31/12 05:33 PM
08/31/12 05:33 PM
Posts: 9,312 SoCal
68HemiB
SoCal
Having seen a brake hone before, my confusion was about the seal contact area being upon the cylinder wall, rather than on the outside of the piston.
Down to just a blue car now.
[Re: 68HemiB]
#1294641
08/31/12 06:31 PM
08/31/12 06:31 PM
MoparMarq
Vancouver, WA
Reman'd unloaded caliper was only 60 bucks. Had a pentastar logo on it.
Not sure if that will do the trick or not, as other auto issues demand attention. BUT, when I got the old caliper off, the slideways on the spindle for the brake pad ears did have some ridges on them. Placing the pads in position in the spindle without the caliper in place and putting forward pressure on them to simulate pad reaction to rotation of the rotor made them very difficult to move laterally because of the ridge on the top slideway. I'm thinking that was the real problem. So, I dremel sanded the ridges off, dabbed some grease on before replacing the caliper/pads. We'll see how it goes...
My 8 YO helper was not here to help with bleeding, so pumped it up myself, then used a short 2x4 wedged between the pedal and electric seat to hold the pedal down to bleed it. Crude, but seemed to work.
