BB 906 heads #1294615
08/31/12 02:32 PM
08/31/12 02:32 PM
Ontario, Canada
B5Superbird Offline OP
Ontario, Canada
I have a set of 906 heads that i want to put on a 1970 Superbird..
How do i figure out when they were made? Reading the casting date..
pics to follow..
Re: BB 906 heads [Re: B5Superbird] #1294616
08/31/12 02:56 PM
08/31/12 02:56 PM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
From my research, the 2843906 heads were manufactured for the '68, '69 and '70 model years only. They were used on the B/RB engines.
Re: BB 906 heads [Re: moparjo68] #1294617
08/31/12 03:19 PM
08/31/12 03:19 PM
Ontario, Canada
Ontario, Canada
Thanks for the response. I know they were made for 68-70 B/RB engines. I'd like to know how to date them, as to when they were cast.
Re: BB 906 heads [Re: B5Superbird] #1294618
08/31/12 03:23 PM
08/31/12 03:23 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
edit
Re: BB 906 heads [Re: JohnRR] #1294619
08/31/12 03:53 PM
08/31/12 03:53 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
68 383 from my Chrysler.
I have mechanical Aptitude.
I can screw up anything.
Re: BB 906 heads [Re: bboogieart] #1294620
08/31/12 04:15 PM
08/31/12 04:15 PM
Ontario, Canada
Ontario, Canada
Ok i've found those cast numbers, they are 11228 and 11268.
I guess they are way off for my Superbird..
Thanks for the help
i guess i'll have to try and fix the original one..
Re: BB 906 heads [Re: B5Superbird] #1294621
08/31/12 04:17 PM
08/31/12 04:17 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Thanks for the help
I'm all for correctness, but since all 906's are the same and you can't see those dates unless you remove a valve cover...
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: BB 906 heads [Re: DPelletier] #1294622
08/31/12 04:58 PM
08/31/12 04:58 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks for the help
But he'll sleep better at night knowing that his heads have the "correct nummers"
Re: BB 906 heads [Re: DAYCLONA] #1294623
08/31/12 05:15 PM
08/31/12 05:15 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Thanks for the help
and it will run better if it has the correct dated heads..
I am truckless..
Re: BB 906 heads [Re: 340SHORTY] #1294624
08/31/12 05:49 PM
08/31/12 05:49 PM
JohnRR Offline
JohnRR  Offline
Thanks for the help
Re: BB 906 heads [Re: JohnRR] #1294625
08/31/12 06:29 PM
08/31/12 06:29 PM
moparjo68 Offline
moparjo68  Offline
I didn't care about the date code when I located my heads. I was just happy to find a good set.
Re: BB 906 heads [Re: 340SHORTY] #1294626
08/31/12 07:29 PM
08/31/12 07:29 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Thanks for the help
i've heard it's good for a easy 5-10hp gain!
Re: BB 906 heads [Re: mikemee1331] #1294627
08/31/12 08:28 PM
08/31/12 08:28 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Thanks for the help
and if you date coded your significant other "somebody" will be running better !!
I am truckless..
