BB 906 heads
#1294615
08/31/12 02:32 PM
08/31/12 02:32 PM
Posts: 119 Ontario, Canada
B5Superbird
Ontario, Canada
I have a set of 906 heads that i want to put on a 1970 Superbird.. How do i figure out when they were made? Reading the casting date.. pics to follow.. Thanks
Re: BB 906 heads
[Re: DPelletier]
#1294622
08/31/12 04:58 PM
08/31/12 04:58 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Ok i've found those cast numbers, they are 11228 and 11268. I guess they are way off for my Superbird..
Thanks for the help i guess i'll have to try and fix the original one..
I'm all for correctness, but since all 906's are the same and you can't see those dates unless you remove a valve cover...
But he'll sleep better at night knowing that his heads have the "correct nummers"
Re: BB 906 heads
[Re: 340SHORTY]
#1294624
08/31/12 05:49 PM
08/31/12 05:49 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
and it will run better if it has the correct dated heads..
Re: BB 906 heads
[Re: 340SHORTY]
#1294626
08/31/12 07:29 PM
08/31/12 07:29 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
i've heard it's good for a easy 5-10hp gain!
