in the process of setting up my sons 416 Duster,
battery is in the trunk and we have an Allstar performance solenoid and a longacre disconnect swith #45785 mounted in the tail panel
i want the whole system to shutoff when the disconnect is turned off,
please look at my diagram and let me know if i am doing something wrong or how to improve it,
I revised my diagram and added an electric fuel pump to the mix, if i run the fuel to that side of disconnect it should cut off correctly, right ??
thanks
340
