At what point do you need a Trans blanket or Shield? #1293348
08/29/12 01:33 AM
08/29/12 01:33 AM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
I was talking to a buddy at a car show the other day and he asked if I was going to be running a trans blanket or shield when the Hemi goes in.
I hadn't even thought about it.
He said he runs a blanket, but talked about the CSI shields.
What are everyone's opinions on which is better.
The car is primarily a street car but will get raced.
572 Hemi, full manual 727 trans.
Re: At what point do you need a Trans blanket or Shield? [Re: SNK-EYZ] #1293349
08/29/12 01:55 AM
08/29/12 01:55 AM
Renton Washington
Triple Threat Offline
Renton Washington
To be NHRA legal 10.99
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: At what point do you need a Trans blanket or Shield? [Re: Triple Threat] #1293350
08/29/12 02:03 AM
08/29/12 02:03 AM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
Thanks!
I'll need to install a roll bar before I can go legally go faster than 11.50 first anyway.
At what point do most people simply put in a trans shield/blanket simply for safety's sake?
Re: At what point do you need a Trans blanket or Shield? [Re: SNK-EYZ] #1293351
08/29/12 05:57 AM
08/29/12 05:57 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Thanks!
NHRA says 10.99 ,but if you like your feet you can at anytime .
Also locking dip stick .
3 layer fire jacket
snell 2005 helmet .
good luck
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: At what point do you need a Trans blanket or Shield? [Re: 10 o to go] #1293352
08/29/12 07:01 AM
08/29/12 07:01 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Ours exploded last season due to the stand in drivers error. It was an older valve body without the low band apply, and he had never driven one or this car before, and lifted in 1st gear when it spun. Well, it broke his foot in three places, and had any of the shrapnel in the car hit him, it may have been far far worse. The floor blew apart, the shifter was in the back seat, the pedals got pushed up under the dash, and there were large chunks of trans and fluid everywhere in the car. Luckily, the car was on its first run, and none of the fluid ignited, and none of the shrapnel hit him. A year later, and he still walks with a limp. Some of the rollers from the sprag were in the car, and they went thru the floor like .22 rounds...Most of the trans was in pieces not much bigger than 2" square.
The track owner said, any chrysler product, no matter what the ET, should be mandated to run a sheild. Like racing in just a T-shirt without a fire jacket or helmet, and not running a sheild, its just an accident waiting to happen with some pretty severe consequences if it all goes wrong. Just because its not required doesn't mean you shouldn't have it. Even when I drive a 13 sec car, I wear a jacket, and harness, helmet, and racing shoes. Our car now has a CSR sheild, new floor, and we still run without a low band apply VB, but that is all I have ever driven, and knock on wood, have yet to forget to up shift before lifting when it spins.
With the chrysler trans, it does not have to be fast to have this happen. And all it takes is one little mistake, and it can let go in spectacular fashion.
Re: At what point do you need a Trans blanket or Shield? [Re: Dragula] #1293353
08/29/12 09:11 AM
08/29/12 09:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A production trans is low band apply(let off the gas
and the engine will slow it down)
Re: At what point do you need a Trans blanket or Shield? [Re: SNK-EYZ] #1293354
08/29/12 09:13 AM
08/29/12 09:13 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He said he runs a blanket, but talked about the CSR shields.
Who are you getting the trans from , for safety sake get the A+A or Coan sprag , and an A+A billet front drum and you'll not really need the shield or blanket, but NHRA will still require it for 10.99 legal.
Re: At what point do you need a Trans blanket or Shield? [Re: JohnRR] #1293355
08/29/12 10:04 AM
08/29/12 10:04 AM
an8sec70cuda Offline
You need either a shield or a blanket AND a billet drum. Mine lasted 2 years before I exploded the stock drum, but when it did come apart it made me a believer. The CSR shield saved my feet, literally. The billet drums are supposed to be bulletproof, but after seeing what happens firsthand when one comes apart, I'm not willing to take the chance of running one w/ a shield.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: At what point do you need a Trans blanket or Shield? [Re: an8sec70cuda] #1293356
08/29/12 10:15 AM
08/29/12 10:15 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Click on this link, go down a few paragraphs, info on when yoiu need a trans shield.
http://www.centervilledragway.com/Rules%20for%20Racers.htm
2011 Drag Pak Challenger
Re: At what point do you need a Trans blanket or Shield? [Re: an8sec70cuda] #1293357
08/29/12 10:22 AM
08/29/12 10:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You need either a shield or a blanket AND a billet drum. Mine lasted 2 years before I exploded the stock drum, but when it did come apart it made me a believer. The CSR sheid saved my feet, literally. The billet drums are supposed to be bulletproof, but after seeing what happens firsthand when one comes apart, I'm not willing to take the chance of running one w/ a shield.
I still run a stock drum (running into the 8s).. you
just cant do stupid stuff... if it spins SHIFT before
you let off.... if you waste the over running clutch
(sprag) it will spin the drum 2.2 times the engine
RPM.. pretty much anything over 6200 rpms with give
it enough rpm to blow the drum with centrifugal force
Re: At what point do you need a Trans blanket or Shield? [Re: MR_P_BODY] #1293358
08/29/12 11:25 AM
08/29/12 11:25 AM
Bad things happen even if you don't "do stupid stuff". I'd never recommend using a stock drum in a high powered car.
CHIP
Re: At what point do you need a Trans blanket or Shield? [Re: an8sec70cuda] #1293359
08/29/12 11:41 AM
08/29/12 11:41 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Or just run a 904 you won't have that problem.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: At what point do you need a Trans blanket or Shield? [Re: DemonDust] #1293360
08/29/12 04:58 PM
08/29/12 04:58 PM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
Kenny Helton built the trans.
He suggested two different choices on upgrading the sprag (both from CRT).
After talking it over with Kenny I chose the stronger 16 roller sprag.
The valve body is a reverse manual (can't remember the brand right now).
He also recommended other internal parts which were used in building the trans.
He didn't feel the drum was absolutely necessary in my trans build for the cost it would add so kept the stock one.
I already bought the locking dipstick from CRT.
I guess now I have to decide which way to go, blanket or shield.
The blanket could probably be installed later but not the shield.
I don't want to have to pull the trans later to install either after the drivetrain is installed.
Thanks for the replies!
Re: At what point do you need a Trans blanket or Shield? [Re: SNK-EYZ] #1293361
08/29/12 07:09 PM
08/29/12 07:09 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i got what you need to decide to run a shield and a front drum.
numidia last year before i split my block a cornet rolled the sprag and dove out of the car bloody foot fire and oil everyware.
he had a blanket.
it did not protect his foot.
i now have a billet steel drum in the front.
Re: At what point do you need a Trans blanket or Shield? [Re: SNK-EYZ] #1293362
08/29/12 07:15 PM
08/29/12 07:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There is really only one choice in rear sprags and that is the 16 roller ,, CRT sells the A+A unit , the Coan has better bolts to hold it but basically the the same .
You built a 572" Hemi, the $700 for the Billet A+A drum is a drop in the bucket.
You definitely need a shield or blanket, just be warned they only slow down the explosion, there have been pictures of cars with exploded 727's where the drum parts still cam thru the floor and they have sheilds and/or blankets.
Re: At what point do you need a Trans blanket or Shield? [Re: SNK-EYZ] #1293363
08/29/12 07:29 PM
08/29/12 07:29 PM
ill
dennismopar73 Offline
ill
I almost went with a blanket, We tried one on Toms car but it would not fit at all!
so we went with a CSR shield , just do your self a favor ane cut that trans.firewall seam out!
As for rear sprags, I have never lost one yet in 727!! I run stock sprags that I bolt in. Same for the drum ! but I don't put 700-1000hp to it either
Rich Can't wait to see the car done!!
Re: At what point do you need a Trans blanket or Shield? [Re: dennismopar73] #1293364
08/29/12 08:29 PM
08/29/12 08:29 PM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
The 572 Hemi isn't an all out race motor, it's a street motor with 10.5 compression, with a 524/292 hydraulic cam.
The only reason it ended up being a 572 rather than a 528 was that I got a deal on a 4.5 inch KB crank.
I was actually looking for a 4.15 crank at the time.
As far as how much HP it will actually have, who knows.
Dan (engine builder) thinks it should be a torque monster.
He thinks that one HP per cubic inch isn't unrealistic.
When it's on a dyno we'll see what it actually does.
Back to the original topic, I'm leaning towards going with the CSI shield.
Like this one.
https://www.coperacingtrans.com/product_...50c3d73c6cd4f57
Re: At what point do you need a Trans blanket or Shield? [Re: SNK-EYZ] #1293365
08/29/12 09:00 PM
08/29/12 09:00 PM
Ohio
Todd Offline
Todd  Offline
Ohio
That's the one I have. Had to trim the ears off the bell housing. Other that the fit is pretty good.
Re: At what point do you need a Trans blanket or Shield? [Re: Todd] #1293366
08/30/12 03:37 PM
08/30/12 03:37 PM
Mansfield,Ohio
Brandon70cuda Offline
Mansfield,Ohio
As others have said when you value your feet more then the shield or blanket costs is when it's time for one.
Re: At what point do you need a Trans blanket or Shield? [Re: Brandon70cuda] #1293367
08/30/12 04:40 PM
08/30/12 04:40 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Just throwing this out there for discussion.
I grew up in Minnesota and the preferred method for getting yourself out of a snowbank or patch of deep snow when you were stuck was to "rock" the car back and forth. You did this by gunning the car in reverse, then jamming into drive or first and gunning it, then jamming it back into reverse and repeating over and over until you finally built up enough momentum to get yourself up and over the snow obstacle and out. I think owner's manuals back then even told you how to do it this way. Lots of tire spinning involved here, probably more brutal than any burnout box. Never heard of anyone exploding their 727 or hurting them in any other way doing this.
So was this because they were stock trans and all had low-band apply? Just curious.
