UPDATED: 95 Ram ASD relay not switching!?!?
#1293175
08/28/12 08:07 PM
08/28/12 08:07 PM
DaytonaTurbo
Manitoba, Canada
Working on trying to get a 95 ram 5.2 running. I noticed a code for the ASD relay, code 42 by doing the on-off-on-off-on thing with the key. I checked the asd relay and found it's not switching on when the key is put to the run position.
I have found a problem to be the wire the ECU uses to ground the relay to make it switch on. A wire my diagram calls ASD relay control. I checked it with my multimeter and with one end on this wire and the other end to battery +, I get 12v whether the key is on or not. Looking at a wiring diagram, it looks to me like the computer is supposed to ground this pin when I turn the key to run, yet this is not turning the relay on. I have spare relays and tried them to no help. I disconnected this wire and ran a wire straight from the relay to ground, causing the relay to turn on and the fuel pump to turn on. When I hit the key it starts and runs for about a second then dies. Any ideas? Sound like my ECU is bad? I followed the wire back to the computer and checked for resistance and it's all good.
Re: Dodge techs.... 95 Ram ASD relay not switching!?!?
[Re: DaytonaTurbo]
#1293176
08/28/12 08:54 PM
08/28/12 08:54 PM
Posts: 92 Michigan
Kudakid
Your correct in that the PCM does ground that pin to energize the relay. Note though, the PCM must see the engine pulses (crank sensor) turning to keep the ASD relay energized, if not it times out after a few seconds. So you would have to check this wire right when you key on to crank to see if the pcm is actually grounding it. That would show the PCM is grounding it so that part of the circutry is working. You grounded the wire yourself to get the fuel pump on and ASD relay energized, but if the crank sensor is not putting out a signal you would get a start-flare based off the fuel squirted in for the engine prime fuel shot, but would die right after if the PCM does not see the crank pulses to keep the injectors firing in sequence. So I would check to make sure the crank position sensor is working. You can do that by connecting a meter with a needle on it across the crank sensor and cranking the engine and seeing if you see the voltage 0-5 volts change while cranking.
2010 Challenger R/T
2001 Jeep Cherokee
1970 AAR Cuda
1970 T/A
[Re: Kudakid]
#1293177
08/28/12 08:59 PM
08/28/12 08:59 PM
Posts: 92 Michigan
Kudakid
If you do need a PCM, I have a new ones (56026790)or(56028322)in the box
2010 Challenger R/T
2001 Jeep Cherokee
1970 AAR Cuda
1970 T/A
[Re: DaytonaTurbo]
#1293180
08/29/12 02:58 AM
08/29/12 02:58 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
The crank sensor has three wires as you know. The signal wire which is 5 volts from the PCM looking to ground and go to 0 volts. One wire is a ground and the other is the power up circuit for the sensor. Some use 12 volts and some use 8 to 9 volts and some even use 5 volts to power them. I believe yours is an 8 volt power up circuit. At 7.4 you may just have a slightly low battery. But the 5 volt signal wire should be either 5 or 0 volts. Unhook the sensor and make sure it reads 5 volts and then ground the wire and make sure it reads 0. If it does it sounds like the crank sensor is the problem but you might want to check the wire diagrahm to make sure the power up circuit is an 8 volt circuit to make sure its not a 12 volt power up circuit which would of course mean a wire problem or PCM problem. I have been away from turning wrenches for 2 years but I think everytime you ground the 5 volt signal circuit with the key on the auto shutdown relay should energize. If you dont have acess to a wire diagrahm let me know as I can still get on the Mopar site and get the wireing for you . Ron
[Re: DaytonaTurbo]
#1293182
08/29/12 10:29 AM
08/29/12 10:29 AM
Posts: 92 Michigan
Kudakid
As said the crank position sensor is a hall effect sensor. The feed is 8volts from the PCM, If your reading 7.4v thats okay as it also is feeding the cam sensor and there will be a voltage drop when reading this. The signal coming from the crank sensor to the PCM is a square wave 0-5 volts. 5 volts when there is no metal in front of the sensor head and 0 volts when the tooth passes in front of the head. So if you back pin the sensor (put meter between ground and signal out)and crank the engine you should see the pulses (0-5 volts). It does take a while to set the code 11. A lot of cranking with no signal. You might have set this code if you tried cranking the engine with the sensor disconnected. Either way, back pin the sensor, crank the engine and see if you get the pulses (0-5volts)
2010 Challenger R/T
2001 Jeep Cherokee
1970 AAR Cuda
1970 T/A
[Re: 70Cuda383]
#1293184
08/29/12 04:49 PM
08/29/12 04:49 PM
Posts: 92 Michigan
Kudakid
Its actually the transition from low to high if memory serves me correct (or vice versa). There is a pattern used, there is more than one tooth/space whatever that application used. The holes or teeth depending on manual/auto application. I believe that system used 4 even markings for one cylinder and a larger gap and three markings so the PCM can detrmine which cylinder is coming up based on the larger gap and the cam sensor input.
2010 Challenger R/T
2001 Jeep Cherokee
1970 AAR Cuda
1970 T/A
[Re: 70Cuda383]
#1293189
09/23/12 06:59 PM
09/23/12 06:59 PM
DaytonaTurbo
Manitoba, Canada
Finally got around to throwing in the correct sensor today. Fits nicely. Hit the key and same thing as before, vroom runs for 2 seconds then quits. Computer is still spitting out code 11 - no crankshaft signal. I have a hard time believing this because if I try and crank it with the sensor disconnected it doesn't try to fire. Same thing if I crank it with the sensor plugged in but unbolted from its hole. So obviously the computer is getting a crankshaft sensor signal. Checked the ground for the crank sensor, it's good, less than 1 ohm of resistance. Checked the wire that's labeled in my diagram as the crankshaft position sensor signal and it's a solid 5.02 volts. The 3rd wire, the one labeled as 8v supply is still only putting out 7.3v at the crank sensor plug, distributor plug and even right at the ECU. Tried it with the battery charger hooked up to make sure I wasn't running low on power and no change. Not sure if this is an issue? ECU is out of the junkyard so I can only assume it was a running vehicle. Any other ideas? I was thinking to pick up a spare ECU at the junkyard to see if that's my problem?? I'm at a loss and annoyed at fighting with this same issue. Power wires, ground wires, everything is new because I went thru it all during the engine swap.
