Page 7 of 14 1 2 5 6 7 8 9 13 14
Re: 1970 RoadRunner SRT8 [Re: KatFysh] #1292908
01/22/14 01:32 AM
01/22/14 01:32 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
how much would the difference in depth be between the RR and the Cuda. I'm thinking that the Cuda would have the needed depth for all that is behind the Charger dash??!! Correct?
I fit everything from an o7 Charger under my 70 GTX dash. Eliminated the side window vent and modified the plenums to redirect the hose. Lots of pics here, you will have to scroll thru the pages to find them though
http://www.forbbodiesonly.com/moparforum/showthread.php?1121-B-Body-stiffening
Driving modern convenience in classic beauty
Re: 1970 RoadRunner SRT8 [Re: Darius] #1292909
01/22/14 11:04 AM
01/22/14 11:04 AM
Springfield, MO- USA
Force28x Offline
Force28x  Offline
Thanks, Darius, that build is sweet.
Re: 1970 RoadRunner SRT8 [Re: Force28x] #1292910
01/31/14 04:07 PM
01/31/14 04:07 PM
Force28x Offline
Force28x  Offline
Craig, did you cover over the trunk extensions, or did they go away for the new trunk floor?
Re: 1970 RoadRunner SRT8 [Re: Force28x] #1292911
03/23/14 01:09 AM
03/23/14 01:09 AM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
Really hope work has continued with this.. I'm sure I'm not the only waiting on updates and more pics...
When you decide to quit, THAT is the moment when you would've succeeded..
Re: 1970 RoadRunner SRT8 [Re: KatFysh] #1292912
03/28/14 02:08 PM
03/28/14 02:08 PM
CJD AUTOMOTIVE Offline OP
Back on this.
Originally I wanted to try and use the front core support.
This pic shows it nose high, but it's rolling!
That wasn't going to work, so I used the upper rail for a little new/old continuity and started fabbing a core support.
Still in progress, but hoping to button up the engine compartment this weekend.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292913
03/28/14 05:50 PM
03/28/14 05:50 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
I NO pics..
Re: 1970 RoadRunner SRT8 [Re: KatFysh] #1292914
03/28/14 08:45 PM
03/28/14 08:45 PM
RS inner panel with attachments for forward fender mount.
Haven't figured out how I will the finish the outside just yet.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292915
03/29/14 06:35 PM
03/29/14 06:35 PM
Starting the other side.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292916
03/29/14 06:54 PM
03/29/14 06:54 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Looking Good Craig....
Re: 1970 RoadRunner SRT8 [Re: KatFysh] #1292917
03/29/14 07:18 PM
03/29/14 07:18 PM
I NO pics..
How about now?
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: johnscudashop] #1292918
03/29/14 08:51 PM
03/29/14 08:51 PM
Thanks John. Waiting to see yours done….!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292919
04/02/14 12:29 PM
04/02/14 12:29 PM
Few more…
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292920
04/02/14 11:08 PM
04/02/14 11:08 PM
Nice work, looks really good.
Re: 1970 RoadRunner SRT8 [Re: ] #1292921
04/05/14 11:51 AM
04/05/14 11:51 AM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
Yep.. I see them..AWESOME. I have a couple of questions {of course}..Radiator mounting; do you have set that low do to the height of the thermostat? It looks like the bottom of the rad is going to be lowest point. That can't be good?? The little corner tab under the header panel; are you using those to tie the inner fender structure to the header panel? Can you show a better pic of those uncovered? I assume they are welded in position?
I'm loving it. If I can get my wifes mind off selling my Cuda, there may be hope of me doing a similar project in the future..Keep the pics coming.. I'll be using them to convince her..lol..
Re: 1970 RoadRunner SRT8 [Re: KatFysh] #1292922
04/07/14 12:40 PM
04/07/14 12:40 PM
That is the original setup of the Charger. They mount it low to slope the hood for aero. It is still above the cradle. It is low compared to the RR's original position, but where I want it for the factory front belly pan. I'll make a small spoiler behind the bumper to connect the belly pan to. This will help direct air around the front tires without it "stacking up" and pushing up on the front bumper. Areo and handling was the last thing considered for these cars 40+ years ago. I need to direct as much air around the car instead of allowing that huge volume to get under it.
Those are the original fender braces. They were square, and I just made a triangle. They are needed to support the fender shape, so I just slotted the inner fender panel to accommodate them.
I'm getting closer on the car and starting to get into the stuff that will show real progress. I am liking it, and would actually love to keep it. Still on the fence about doing another. I was WAAAYYY to cheap on this one.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292923
04/10/14 12:27 PM
04/10/14 12:27 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
I am glad that you are posting the pics of what you are doing. It gives me a better understanding and it may help me to convince my wife.. .. At first, I had planned on dropping in a Magnum 5.2l and doing what I could to build a "retro/cruiser" type ride with modern conveniences.. See how you are doing this, I think I'd like this direction better..
I am going to lay out a material build sheet to check the difference of cost between what I had planned and what you are doing. I think your way will end up the less costly.
Re: 1970 RoadRunner SRT8 [Re: KatFysh] #1292924
04/15/14 11:10 AM
04/15/14 11:10 AM
Measuring up for wheels. The 295's are close in the back and the 275's in the front are really too wide. Try again with 275's and 245's….
This stance is getting close.
295's.
275's.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292925
04/17/14 01:33 AM
04/17/14 01:33 AM
I like the 295/275 combo, suites the big B-body.
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292926
04/17/14 02:42 AM
04/17/14 02:42 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Are there any other options for wheel offset? There are guys running 275 all the way around on A-bodies with a little modification and the right setup. I would assume your Roadrunner should have more room for meat.
Re: 1970 RoadRunner SRT8 [Re: MuuMuu101] #1292927
04/17/14 11:47 AM
04/17/14 11:47 AM
Remember this is a LX strut front and not a Roadrunner Got plenty of room, just hitting the LX spindle.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
