My Mirada has just started making a kind of popping noise when driving over bumps recently. It doesn't happen all the time, it only seems to start after driving the car for about 1/2 hour or more, then it will do it over every little bump. Leaning on the fender hard enough when the car is parked will do it too.
Then it seems after the car is parked for a while and every thing is cool the noise will go away again. It seems to be coming from the lower ball joint or the edge of the lower control arm.
The weird thing is, all the ball joints, bushings and tie rods are new. I replaced it all with Moog stuff back in May. However, it was making a similar noise on the driver side back before I changed everything in the front end, and I recall the ball joint on that side being pretty loose when I got it all apart. After changing it out, the problem disappeared until now. I can only guess the lower ball joint is going out on the passenger side now, I thought Moog made decent stuff but I'd expect one of the cheap chinese ones to last longer than 4 months.
