Need help with electrical problem #1292707
08/28/12 08:51 AM
08/28/12 08:51 AM
Mohnton, Pa
DodgeCharger Offline OP
Mohnton, Pa
71 cuda all new wiring from Year One the car was restored in 2004.
I think it is the voltage regulator but not sure I replaced the regulator and it work for a couple of week. 15 miles.
The car started and ran with the new regulator.
the voltmeter in the car worked fine until I ran the car hard. Maybe reved the motor to 6000 rpm.
The voltmeter showed over charging then after a while it droped to the center. Not charging or discharging.
When I shut the car off it was dead. This is the same thing that happend with the original Voltage regulator.
The battery has a full charge but the car doesn't have any power going to it.
Not even the clock will run.
Then If I un hook the battery or the voltage regulator and reconnect it everything will work.
What is going on here? I didn't know that a voltage regulator could stop all power from leaving the battery.
Re: Need help with electrical problem [Re: DodgeCharger] #1292708
08/28/12 11:59 AM
08/28/12 11:59 AM
It cannot. Start with seperating the bulkhead & see if the fusible link is loose. You want to check each connection/terminal from the batt positive post in to the ign switch to find the loose/open connection
Re: Need help with electrical problem [Re: RapidRobert] #1292709
08/28/12 02:47 PM
08/28/12 02:47 PM
Mohnton, Pa
Mohnton, Pa
I think my problem may be the amp meter. It is original. The lights don't go through the ignition switch and when it acts up even the lights and clock won't work.
Re: Need help with electrical problem [Re: DodgeCharger] #1292710
08/28/12 03:57 PM
08/28/12 03:57 PM
Glendale AZ
jimmyc340 Offline
jimmyc340  Offline
Glendale AZ
try the ceramic resistor on the firewall first
Re: Need help with electrical problem [Re: jimmyc340] #1292711
08/28/12 06:09 PM
08/28/12 06:09 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Can't be ballast. As mentioned, bulkhead conn is #1 suspect, followed by fuse link and ammeter lugs.
Rick
Re: Need help with electrical problem [Re: jimmyc340] #1292712
08/28/12 09:44 PM
08/28/12 09:44 PM
Mohnton, Pa
Mohnton, Pa
I don't have a ballast resistor on my car. Also from what I remember with a bad ballast resistor the car will turn over the lights will work but it just won't fire.
