Re: 67-69' Baracuda Big Block conversion
[Re: 2qik4u]
#129269
09/28/08 10:24 PM
09/28/08 10:24 PM
Look at www.bigblockdart.com. Look at tech pages for lots of options on basic swap issues. Pete
[Re: 2qik4u]
#129271
09/28/08 10:57 PM
09/28/08 10:57 PM
Posts: 388 wine valley
cudaben1968
wine valley
i have a 68 barracuda with a 440 originally a slant 6. first off a 273 to a 440 the wiring is different, not huge just different, the slant 6 and 383 68's used the same wiring harness. i used schumached motor mounts when i had the 383 in mine now sporting a 543 and now i switched to a motor plate. ....headers are a pain if your looking for flow b/c they dont like to fit, i also used the schumacher tri y's easy fit just kinda small i have cppas now. full length is a beeotch. a bb 727 is needed if going auto and you will need to have your driveshaft modified or a new one. the rear end is most likely an 8 1/4 so that will need to go. i got a van 8 3/4 and cut it then had my axles resplined and shortened. realativly inexpensive. if you want more street than stip id go with bigger torsion bars but the 273 ones will work, im running 318 outa 73 dart which i got my disk brakes from actually my whole k-frame upper and lower control arms. i tried the slant 6 bars and it sucked in the corners. lots of work but its worth it in the end, an easier way is to buy one that has all that done. seems like you can find them cheap people tend to lose interest when it gets expensive and they see no real changes for all the money thay have into it. good luck, mine has been a 10 year project just bits and pieces here and there.
Half measures availed us nothing. We stood at the turning point.
-Alcoholics Anonymous, The Big Book
[Re: cudaben1968]
#129272
09/29/08 12:12 AM
09/29/08 12:12 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Spend some time in the tech pages at www.bigblockdart.com. The rear end is either a 7-1/4 or 8-3/4. If it is a 68 the original engine is either a 225 or 318 (barring it being a Formula S). Disc brakes were optional on the 68, to.
[Re: formula_s]
#129273
09/29/08 06:15 PM
09/29/08 06:15 PM
Posts: 484 The State of Hockey
2qik4u
The State of Hockey
no 273's in 68 barracudas.no 8 1/4 rears in those cars either.
My bad, car is a 67'. Does that change things much???
