Re: Small block intake gaskets.
[Re: elmor]
#1292436
08/27/12 11:11 PM
08/27/12 11:11 PM
Posts: 15,487 Florida
scratchnfotraction
Stock 2 barrel intake, 360 heads. Same type of gaskets that were on it.
right there is the problem,small port intake on large port heads.
you need a felpro composit gasket for the large port heads to get a seal with the small port intake.
the tin gasket is for small port heads with small port intake both cast iron.
[Re: elmor]
#1292437
08/27/12 11:13 PM
08/27/12 11:13 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
If you're using 360 heads with a 318 intake manifold, you're going to have a massive port mismatch in terms of size. Add steel gaskets....and you have a sure leak. As mentioned, use 340/360 composite gaskets, and you'll be good to go
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: meep_meep]
#1292438
08/27/12 11:38 PM
08/27/12 11:38 PM
Posts: 4,884 Michigan
MNobody
nothing short gasket replacement is going to fix the leak..just replace them with felpro composite gaskets...
MS90109
