Temp sending unit #1292229
08/27/12 12:29 PM
08/27/12 12:29 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey Gang.
I was curious if anyone has a good part number for a Mopar temperature sending unit (gauge) for our older Mopars. I'm putting together my friend's '71 v-code Challenger R/T and asked him to get an OEM sending unit because the ones I've gotten in the past from the local parts store were never accurate or didn't work properly. I ran into this experience for myself on my former '69 Charger 500, hence wishing to get the OEM product. I got back to me and stated that the only thing a local dealership could come up with was a dual-pin sending unit. I told him our era sending units didn't have any "dual-pin"..
Thanks in advance..
Troy
Houston Mopar Connection Club
Re: Temp sending unit [Re: hemi68charger] #1292230
08/27/12 03:17 PM
08/27/12 03:17 PM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
I'm guessing you need the temp sender with the single threaded head shaft? Year One has a New Chrysler temp sender that I'm planning on buying when they have their next 30% off sale as their everyday price is 46.99. I had hoped Napa's Echlin temp sender would be of better quality but they were all off, just like all the other aftermarket crap. I would email you the link from Year One but am too dumb. The Year One part number is FD51140.
Re: Temp sending unit [Re: moparjo68] #1292231
08/27/12 03:28 PM
08/27/12 03:28 PM
Houston, Tx
Houston, Tx
Nope, that's all good.. I can get there and refer it to my friend, he's been ordering stuff from them anyways... Sooo, I'll just have him add this to the mix....
Troy
Re: Temp sending unit [Re: moparjo68] #1292232
08/27/12 04:52 PM
08/27/12 04:52 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Add an "R" to the YO part number and it's only $12...since it's still an FD (Factory Direct) part number I wonder what the difference is.
Re: Temp sending unit [Re: John_Kunkel] #1292233
08/27/12 06:09 PM
08/27/12 06:09 PM
Houston, Tx
Houston, Tx
I was hoping someone would have mentioned this, I just didn't know...:)
Troy
Re: Temp sending unit [Re: hemi68charger] #1292234
08/27/12 06:41 PM
08/27/12 06:41 PM
moparjo68 Offline
moparjo68  Offline
I saw that as well at the YO site. The caption for the "R" states its aftermarket. So I'm guessing that's the same piece of crap you could buy from any of the auto parts stores.
Re: Temp sending unit [Re: hemi68charger] #1292235
08/27/12 10:08 PM
08/27/12 10:08 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
The 70-71 Chrysler parts book lists the temp sender as part# 2426458. I believe that is superceded to #4051140, which I think is what YO is selling as FD51140 (I have found that sometimes with original Chrysler parts YO replaces the first 2 digits with FD).
You could check with your local dealer regarding the number supercession/availability.
EDIT: Just did a Google search for #4051140 and RT Speciaties shows it changed to #4504202, so you might want to check that number also at your dealer.
http://www.rtspecialties.net/proddetail.asp?prod=4051140
Re: Temp sending unit [Re: moparfan53] #1292236
08/28/12 08:13 AM
08/28/12 08:13 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
I need one too! I thought it was just my car.
Re: Temp sending unit [Re: wally426ci] #1292237
08/28/12 01:55 PM
08/28/12 01:55 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I heard that Shannon at Redline Gaugeworks says you can add a resistor inline to the aftermarket temp senders to get them to read correctly.
Is anyone sure the current over the counter Mopar Parts temp senders work correctly?? Most of time a parts like that is sourced through and outside vendor.
Re: Temp sending unit [Re: moparjo68] #1292238
08/28/12 04:26 PM
08/28/12 04:26 PM
Rio Linda, CA
Rio Linda, CA
That's the logical explanation but if it's aftermarket it shouldn't have a "FD" (Factory Direct) prefix.
Re: Temp sending unit [Re: autoxcuda] #1292239
08/28/12 11:44 PM
08/28/12 11:44 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
I added a 10 ohm resistor to my temp wire as it goes into the harness near the sender [you don't see it as it is only an inch long]. Solder it in and wrap with tape to match.
I used a parts store sender and it read too high [temp]. Tried a couple resistors and the 10 ohm was correct for my guage to be accurate.
Don't forget to verify your actual water temperature when you try different resistors.
Re: Temp sending unit [Re: pacifica] #1292240
08/29/12 07:22 PM
08/29/12 07:22 PM
moparjo68 Offline
moparjo68  Offline
Has anyone bought one of the FD51140 sending units NEW FROM CHRYSLER? And the next question would be.........were they more close to being accurate than aftermarket auto part store no name brand???
Re: Temp sending unit [Re: moparjo68] #1292241
08/30/12 09:11 AM
08/30/12 09:11 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
I had one of these and sold it .....many of the older nors temp senders look just like it...
Re: Temp sending unit [Re: Joesixpack] #1292242
08/30/12 09:14 AM
08/30/12 09:14 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
close up
Re: Temp sending unit [Re: Joesixpack] #1292243
08/30/12 09:17 AM
08/30/12 09:17 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
ehlin&niehoff units were very close
Re: Temp sending unit [Re: Joesixpack] #1292244
08/30/12 03:47 PM
08/30/12 03:47 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
How many do you want ?
Re: Temp sending unit [Re: 62maxwgn] #1292245
08/30/12 04:08 PM
08/30/12 04:08 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Re: Temp sending unit [Re: 62maxwgn] #1292246
08/31/12 09:51 AM
08/31/12 09:51 AM
Houston, Tx
Houston, Tx
Dang Boy !!!
Troy
Re: Temp sending unit [Re: 62maxwgn] #1292247
08/31/12 12:02 PM
08/31/12 12:02 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Oh,,,,I don't know how about ,,,,,
all of them
Re: Temp sending unit [Re: gtx6970] #1292248
08/31/12 09:59 PM
08/31/12 09:59 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Just one please.
I can't afford this. mark
