Re: roll cage ?
[Re: moparmafia]
#1292105
08/26/12 11:46 PM
08/26/12 11:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I was checking on the price for a rollcage and a 10 point moly cage installed by a professional is going to run 2250. i have never had a cage put in but price seems kinda steep. also is it worth the extra cost vs. mild steel. it is going in a roadrunner.
Yes it worth it if you want a light car... if he is suppling the moly tubing and bending it that is not far off.... have you tried buying moly tubing.. that stuff is crazy on price
Re: roll cage ?
[Re: moparmafia]
#1292108
08/27/12 12:21 AM
08/27/12 12:21 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
My do the 4130 tube now or you will wish you had later.
"Just a Bracket car dressed up like a streetcar"
Re: roll cage ?
[Re: LA360]
#1292111
08/27/12 08:54 AM
08/27/12 08:54 AM
Posts: 494 IL
EchoSixMike
IL
Nothing structually wrong with MIG and DOM, it's just that a lot of people doing things poorly do it that way. All the roundy round stuff is MIG/DOM; as is most road race stuff. TIG has a higher cost of entry and requires more skill, and everybody knows it. So the entry level guys go MIG and get in over their head.
IMO, a lot of the issues with MIG are guys trying to be cheap with 115v units and lack of practice/experience. S/F...Ken M
Re: roll cage ?
[Re: earthmover]
#1292115
08/27/12 01:56 PM
08/27/12 01:56 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
Seems like a fair price to me. My 25.5 was alot cheaper than that but that was with myself & some buddies doing it ourselves & I bought/supplied the tubing. Don't know the weight difference overall. But I remember when one of my buddies went from a mild steel 10 point cage to a moly 25.5 cage his car was still almost 50 lbs lighter with the new cage & more bars.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: roll cage ?
[Re: moparmafia]
#1292117
08/27/12 03:38 PM
08/27/12 03:38 PM
Posts: 7,506 Az
Crizila
Az
Size for size the weight difference between ERW, DOM, and moly is negligible. The weight difference is due to the difference in strength - you can use smaller and thinner wall tubing with Moly verses the other two and still have the same strength rating. With a 10 - 12 point cage, the weight difference would probably be in the 30 lb range. Obviously, the more tubing you use, the greater the weight savings would be - if you went with Moly. Strength ( by itself ) isn't really an issue ether. You have to meet the sanctioning bodies spec, no matter what you use. I'm not advocating one over the other. When I built my cage, I went with DOM. I mig'ed it. Dispite what others my say, IMO, Strength and quality of the work is mostly due to the person doing the work, not the type of welder or tubing used. Since I am the driver, I had a vested interest in doing it right. I also went in to my project with plenty of welding experience ( both mig and tig ).
Fastest 300
