Ign ECU Q... Where is my start/run voltage going??
#1291661
08/26/12 02:44 PM
08/26/12 02:44 PM
Posts: 139 MA
limelight440
MA
440 w/ MP orange box (ballast ohms ~1.6) Car is hard starting, has been for some time. WOULD A BAD ECU CAUSE EXCESSIVE DRAW ON START & RUN CIRCUITS??? I take the following readings without my clutch safety switch pressedi in (no starter).
With both ballast resistor leads removed, the run side gets 12v with ign switch in run & the coil side gets 12.5v when ign switch is in start
plug the leads to the resistor though, and RUN is only getting 5v(AT COIL) or so & START is only getting 11v(AT COIL)
What I have been doing, is unplugging one connector from the ballast resistor. This allows the engine to fire (start) but not run. Once the cylinders fire, I plug in both sides of the ballast & the engine starts & runs.
NOTE: When I unplug the ECU, all voltage readings are as would be expected across the ballast & at the coil.
Re: Ign ECU Q... Where is my start/run voltage going??
[Re: limelight440]
#1291666
08/26/12 04:28 PM
08/26/12 04:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
When measure voltages with no load (connector unplugged) you should read battery voltage, you are not.
When reading voltage with a load (connector plugged in) you are reading low voltages. Your problem isn't the ECU, it is the supply to the ballast/coil/ECU. Clean up and tighten all you connections, take a voltage measurement at each connection to see where the loss is. I usually start at eh bulkhead connector as that is usually the culprit.
