Re: 1974 D100 440 misfiring at 4500 rpm
[Re: karmakritters]
#1291256
12/05/12 08:52 PM
12/05/12 08:52 PM
RapidRobert
10/35 is conservative timing more so the 10 especially with no vacuum advance. Make a mark on your dampener at 2&7/32" clockwise from the TDC slit to verify you are at 35 total. If good there I'd get the TDC tool & install it in the #1 plug hole & verify that the TDC slit is correct but I imagine it will be as dampener slippage is rare. Sure sounds like too much timing though. EDIT I reread the posts & it WAS running OK at one point with this timing correct? I was thinking the cam could be machined wrong but that is rare & I always want to k.i.s.s. but same deal it ran OK prior with this cam/timing. Something ain't adding up
[Re: karmakritters]
#1291258
12/05/12 10:46 PM
12/05/12 10:46 PM
Posts: 4,872 connecticut
pnypwr
connecticut
did you change the ignition box? I had a pertronix that did that to me. i run msd in everything and can count all the problems on oh wait ive never had a problem with an msd!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
