1974 D100 440 misfiring at 4500 rpm
#1291229
08/25/12 04:43 PM
08/25/12 04:43 PM
karmakritters
Hello, I am new here and really need some help. The truck has a 1971 440 with flat top forged pistons,forged crank,LY rods, lunati 509 lift cam,516 heads ported with 2.14/1.74 valves, edelbrock performer intake and a holley 800 mechanical secondaries carb.
So far I have changed plugs,wires,distributor,cap,rotor, fuel pump,carb, still starts popping at 4500 rpm no matter what I try. I have also disconnected the gas tank and ran the fuel pump from a clean container hoping it was a tank issue to no avail. The timing is at 10 degrees advance at idle and pulling to about 35 degrees total at 3200 rpm. Thanks in advance, Sam
Re: 1974 D100 440 misfiring at 4500 rpm
[Re: karmakritters]
#1291232
08/25/12 06:59 PM
08/25/12 06:59 PM
RapidRobert
Either rotor phasing or fuel delivery. Caps and rotors are carbon copies and will not change rotor phasing. Having no vac adv makes it easier to sort out. Generally running the car up thru the gears if it is ign it will miss in all 3 gears at the same LOAD and RPM. If it's good at 4500 in 1st and 2nd then acts up in 3rd that points to fuel delivery as it takes time for the need to outstrip the delivery unless the fuel delivery system is EXTREMELY inadequate which I do not think is the case here. Whereas an ign miss will happen at the same load/rpm no matter what gear you are in. I'm thinking fuel but if need be drill the hole in the cap & check rotor phasing at idle. Ign sub issues; MAY need a rotor with a .060" longer blade NAPA Echlin MO3000 which helps some with phasing issues(& we can fix phasing directly) and check ECU ground and pickup gap but first let's pin it down to ign or fuel
[Re: karmakritters]
#1291234
08/25/12 07:53 PM
08/25/12 07:53 PM
RapidRobert
Yours must have a vent hole. Not sure where it is located. You want a seperate drilled hole in the roof flat 2/3 of the way between the center terminal and the #1 plug wire terminal so you can look down & see if the rotor metal blade is pointed too far in front of or behind being dead even with the metal cap terminal around the circumference while running using the timing light
[Re: karmakritters]
#1291235
08/26/12 08:30 AM
08/26/12 08:30 AM
Posts: 5,894 Florida
Locomotion
You didn't say which ignition system you are using. If it's the Mopar style with an ignition box (OEM/Orange/Chrome), try another "known" good one. I've seen a couple of the Chrysler style boxes act like rev limiters.
Not sure if other brand boxes can malfunction in a similar manner.
Do you recall if it started after you changed anything? Always run 35* timing? Different brand fuel? Change plugs? (Oops, nevermind on the plugs!)
[Re: karmakritters]
#1291239
08/27/12 09:29 PM
08/27/12 09:29 PM
RapidRobert
To the right (clockwise) of #1 would be the #2 terminal & we're still missing something as it would not run if it was that far off & if the drilled hole is between the center & #1 you would not be able to see the rotor blade that far off & tell that it's in the middle unless I'm missing something.
