A-Body Shocks with SS Springs? #1291216
08/25/12 03:48 PM
08/25/12 03:48 PM
Oahu, Hawaii
P
ParadiseCuda Offline OP
P
Oahu, Hawaii
What rear shocks work best in a 73 Dart with Super Stock springs (002/003)? I seem to recall that a longer shock is required with the super stock springs.
Re: A-Body Shocks with SS Springs? [Re: ParadiseCuda] #1291217
08/25/12 06:09 PM
08/25/12 06:09 PM
North Dakota
440abody Offline
440abody  Offline
North Dakota
Mopar performance P/N: P4529514
Or measure the distance between the centerline of each mounting stud and go to your local NAPA and look for some that will fit. That is what I did, and found (if I can remember correctly) a shock for a 2wd Ford truck from the 70's that fit. Remember to check full extention and compressed to get the best fit.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: A-Body Shocks with SS Springs? [Re: ParadiseCuda] #1291218
08/25/12 07:59 PM
08/25/12 07:59 PM
AndyF Offline
AndyF  Offline
Old trick was to use C-body shocks, or shocks from a Dodge 1/2 ton truck.
Re: A-Body Shocks with SS Springs? [Re: AndyF] #1291219
08/25/12 09:30 PM
08/25/12 09:30 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I'm running Rancho 9000's. Work great for me.
Re: A-Body Shocks with SS Springs? [Re: bigblock340power] #1291220
08/26/12 12:45 AM
08/26/12 12:45 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If you go with the C-body shocks, and are at an O'Reilly's, they have the applications goofed up. Look for the Police application, as their computer listed the wrong ones for the regular cars.
Re: A-Body Shocks with SS Springs? [Re: bigblock340power] #1291221
08/26/12 04:26 PM
08/26/12 04:26 PM
Oahu, Hawaii
P
P
Oahu, Hawaii
Thanks or all the replies. I will check out O'reilly for the "C" body shocks.
BigBlock340Power, do you know the part number of the Rancho 9000s you are using?
