Best custom converter for the $$$ #1290961
08/25/12 01:31 AM
08/25/12 01:31 AM
PA
W
w7smallblock Offline OP
W
PA
Who has the best custom converter for the $$ or should I say who gets it right the first time or at least real close? This is for a street strip 408, not an all out race car. I'm looking for people with first hand experience not second hand info and I will not buy a Dynamic.
Re: Best custom converter for the $$$ [Re: w7smallblock] #1290962
08/25/12 01:37 AM
08/25/12 01:37 AM
Turbo Action, CRT, or ATI on the east coast
Re: Best custom converter for the $$$ [Re: Cab_Burge] #1290963
08/25/12 09:02 AM
08/25/12 09:02 AM
Sullivan, Ohio
Max Wedge Savoy Offline
Sullivan, Ohio
Lupo's converters have never let me down. Dynamic transmission.
Re: Best custom converter for the $$$ [Re: Max Wedge Savoy] #1290964
08/25/12 09:08 AM
08/25/12 09:08 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i went with Turbo Action. their converter put me in the winners circle right on day one, had to spend a bit of coin but it's perfect & bulletproof so far, & thats 9 years of abuse it's endured.
Re: Best custom converter for the $$$ [Re: rebel] #1290965
08/25/12 09:22 AM
08/25/12 09:22 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
PTC
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Best custom converter for the $$$ [Re: Plumb Wired] #1290966
08/25/12 09:35 AM
08/25/12 09:35 AM
ill
dennismopar73 Offline
ill
Dynamic, if given enough info they make one of the best hands down, ,,Turbo Action, been another one of the best for years, altho, the last one we got and sent back 3 times has been a very bad miss on setup, but it works! they just cant get to the 5200-5500 I need, , it's best is 4800,, every time I send it in Paul says you will send it back to have it tightened up!!,, nope , I gave up, Just run it!!
I took a GER out to put in the above verts, I gained nothing, I still Have my GER, just in case I need a spare!!
Re: Best custom converter for the $$$ [Re: w7smallblock] #1290967
08/25/12 09:52 AM
08/25/12 09:52 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
PRO TORQUE was dead on 5000 first time,told em i needed 500 more the next yr,189 bucks later again dead on..ps about a 1/2 drive if that from ur house Chuck
Re: Best custom converter for the $$$ [Re: fishy340] #1290968
08/25/12 10:01 AM
08/25/12 10:01 AM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
Ultimate Converter with out a doubt. You not find a better experience than dealing with Lenny and Dawn.
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Re: Best custom converter for the $$$ [Re: w7smallblock] #1290969
08/25/12 11:13 AM
08/25/12 11:13 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Talk to Andre ar Edge Racing Converters, I have a 9.5" that was built for my 340. It was sent back and went through for my street/strip 408, it flashes 5000 and works great on the street and strip. My Dart is 3260# with me in it and has gone 1.38 60' in good air and will go 1.41-2 in the heat on drag radials.
http://www.edgeracingconverters.com/index.php?main_page=index&cPath=7
Re: Best custom converter for the $$$ [Re: w7smallblock] #1290970
08/25/12 11:18 AM
08/25/12 11:18 AM
SoCal
Brian Hafliger Offline
SoCal
A1 and ATI are the really ONLY players who know converters IMO.
Brian
Brian Hafliger
Re: Best custom converter for the $$$ [Re: Brian Hafliger] #1290971
08/25/12 11:26 AM
08/25/12 11:26 AM
Out West
408strokerdart Offline
Out West
Ultimate will get it right the first time. I have heard good things about PTC as well.
Re: Best custom converter for the $$$ [Re: Plumb Wired] #1290972
08/25/12 12:03 PM
08/25/12 12:03 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
PTC
Re: Best custom converter for the $$$ [Re: w7smallblock] #1290973
08/25/12 12:31 PM
08/25/12 12:31 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Give Jason Brock a call at Quick Draw converters. Really knows his stuff and is VERY reasonable.
Re: Best custom converter for the $$$ [Re: w7smallblock] #1290974
08/25/12 01:40 PM
08/25/12 01:40 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Spend the money and go with a 8" instead of a heavy 9.5"(edge). I just made this change and lost 8 lbs of mass and picked efficiency. I'm still a little loose for my combo, but the car picked up big time.
"Just a Bracket car dressed up like a streetcar"
Re: Best custom converter for the $$$ [Re: SB412DUSTER] #1290975
08/25/12 02:02 PM
08/25/12 02:02 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
PTC
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Best custom converter for the $$$ [Re: D-50] #1290976
08/25/12 02:46 PM
08/25/12 02:46 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
I know I am alone here but here goes, and then let the stone throwing begin. I have never had any luck with PTC in an NA application. In fact I would go so far as to say had nothing but problems. Customer service was great but way to many issues with simple things soured me on them.
We have had excellent luck with ATI and A1 over the years. Probably purchased 30+ converters from the two of them. I have tried many and always end up going back to these two, depending on the application.
Re: Best custom converter for the $$$ [Re: Al_Alguire] #1290977
08/25/12 02:50 PM
08/25/12 02:50 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
No, you aren't alone.
Re: Best custom converter for the $$$ [Re: Al_Alguire] #1290978
08/25/12 03:25 PM
08/25/12 03:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Continental in So. Cal.................
Re: Best custom converter for the $$$ [Re: Al_Alguire] #1290979
08/25/12 04:21 PM
08/25/12 04:21 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I witnessed first hand one episode that I'm sure Al was thinking of.... and were not talking missing the setup, we're talking failure! Repeated failure. It was so bad in the end that the victim had two converters from them and eventually switched companies. I know I'd never use them.
Re: Best custom converter for the $$$ [Re: D-50] #1290980
08/25/12 04:24 PM
08/25/12 04:24 PM
Hampton Va
gtsdon Offline
gtsdon  Offline
Hampton Va
Another vote for PTC.
