Re: Best custom converter for the $$$
[Re: Plumb Wired]
#1290966
08/25/12 09:35 AM
08/25/12 09:35 AM
Posts: 2,177 ill
dennismopar73
ill
Dynamic, if given enough info they make one of the best hands down, ,,Turbo Action, been another one of the best for years, altho, the last one we got and sent back 3 times has been a very bad miss on setup, but it works! they just cant get to the 5200-5500 I need, , it's best is 4800,, every time I send it in Paul says you will send it back to have it tightened up!!,, nope , I gave up, Just run it!! I took a GER out to put in the above verts, I gained nothing, I still Have my GER, just in case I need a spare!!
[Re: w7smallblock]
#1290974
08/25/12 01:40 PM
08/25/12 01:40 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Spend the money and go with a 8" instead of a heavy 9.5"(edge). I just made this change and lost 8 lbs of mass and picked efficiency. I'm still a little loose for my combo, but the car picked up big time.
"Just a Bracket car dressed up like a streetcar"
[Re: D-50]
#1290976
08/25/12 02:46 PM
08/25/12 02:46 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
I know I am alone here but here goes, and then let the stone throwing begin. I have never had any luck with PTC in an NA application. In fact I would go so far as to say had nothing but problems. Customer service was great but way to many issues with simple things soured me on them.
We have had excellent luck with ATI and A1 over the years. Probably purchased 30+ converters from the two of them. I have tried many and always end up going back to these two, depending on the application.
[Re: Al_Alguire]
#1290977
08/25/12 02:50 PM
08/25/12 02:50 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
No, you aren't alone.
[Re: Al_Alguire]
#1290978
08/25/12 03:25 PM
08/25/12 03:25 PM
Thumperdart
State of confusion
Continental in So. Cal.................
[Re: Al_Alguire]
#1290979
08/25/12 04:21 PM
08/25/12 04:21 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
I witnessed first hand one episode that I'm sure Al was thinking of.... and were not talking missing the setup, we're talking failure! Repeated failure. It was so bad in the end that the victim had two converters from them and eventually switched companies. I know I'd never use them.
