Windshield Gasket- worth saving? #1290597
08/24/12 07:08 PM
08/24/12 07:08 PM
NW Pennsylvania
areibel Offline OP
areibel  Offline OP
NW Pennsylvania
I'm starting on my 69 Charger, and I need to remove the cracked windshield. I have all the trim removed, but I was wondering if it's worth trying to save the original gasket? It feels hard as a rock, but it looks in good shape. But will trying to R&R the glass just chew it up anyway?
Thanks,
Al
Re: Windshield Gasket- worth saving? [Re: areibel] #1290598
08/24/12 07:41 PM
08/24/12 07:41 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I would toss it and use a new one.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Windshield Gasket- worth saving? [Re: areibel] #1290599
08/24/12 10:04 PM
08/24/12 10:04 PM
chances are if it is hard as a rock, it will either tear or leak when a new windshield is installed. cheap insurance is to get a new gasket!
Re: Windshield Gasket- worth saving? [Re: ] #1290600
08/24/12 11:07 PM
08/24/12 11:07 PM
western australia
1cuda Offline
1cuda  Offline
western australia
sorry to hijack your post but if your windshield is cracked you should be able to get the seal out without damage-if you think it`s too brittle don`t use it as you don`t want a leak-i heard if you place the rubber in one of those hot water rotowash machines they come back to life like new-maybe worth a try.
one day i need to restore my 69 charger r/t and it too has the original rubber which is not brittle -i`m not wanting to save the rubber but i must save the windshield as it is in perfect condition and dated correct. what is the best way to save the windshield? cut the rubber until the windshield falls out or is there a better way that someone has tried before. i might consider restoring the car with the windshield still in place-could be another option as it is a low mile car.
all the best
frank.
Re: Windshield Gasket- worth saving? [Re: areibel] #1290601
08/24/12 11:37 PM
08/24/12 11:37 PM
NW Pennsylvania
areibel Offline OP
areibel  Offline OP
NW Pennsylvania
Thanks, I think I will just spring for a new one.
I was messing around with it a little earlier, I got the lock strip all popped out but the outer edge (outside the trim that took all the weather and sun) is pretty stiff. Maybe get it out and offer it on Ebay- Rare, vintage, almost NOS!
Re: Windshield Gasket- worth saving? [Re: areibel] #1290602
08/25/12 01:25 AM
08/25/12 01:25 AM
MERRILLVILLE, INDIANA
sunroof446 Offline
sunroof446  Offline
Save it. Repro's do not fit very well on te bottom where it lays on the dash board. If you use a repro make sure you trim off all the moulding [Edited by Moparts - Family Friendly Site - Keep it clean] and extra rubber from the mold or it will not fit right.
Re: Windshield Gasket- worth saving? [Re: sunroof446] #1290603
08/25/12 05:38 AM
08/25/12 05:38 AM
western australia
1cuda Offline
1cuda  Offline
western australia
thank you-i think i know what i`m going to do now
all the best
frank
