1971 Hood Release Cable handle Keeps Sliding Off!!!
#1290384
08/23/12 10:59 PM
08/23/12 10:59 PM
Posts: 178 New England
69Stinger
New England
OK - I found an NOS inside hood release cable for my 71 RR when it was being restored (The one with the plastic chrome handle) and now every time I pull it to open the hood, the handle slides off into my fingers. With the car now done, it's now become more than a pain in the @ss. I have to then pop the hood with a pair of pliers. I don't want to ruin an NOS handle/cable - what can I do to fix it - some kind of special plastic to metal glue ? Thanks
Re: 1971 Hood Release Cable handle Keeps Sliding Off!!!
[Re: 69Stinger]
#1290385
08/24/12 06:54 PM
08/24/12 06:54 PM
Posts: 4,796 Castlegar, BC, Canada
That AMC Guy
I would try either an epoxy or JB Weld. Failing that, drill a small hole for a set screw but that may crack the plastic handle over time. I've had to do this on pretty much every AMC I've owned. I've had good luck with the JB Weld.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: That AMC Guy]
#1290386
08/24/12 07:13 PM
08/24/12 07:13 PM
Posts: 4,920 new berlin wisconsin
Mr T2U
glue it on with jb weld. when the glue is dry, drill a small hole in the handle and rod. then jb weld in something like a pin in the hole you just drilled.
perception is 90% of reality
