440 ez heads or edelbrock victor max port?
#1290234
08/23/12 07:18 PM
08/23/12 07:18 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i'm building a 505 stroker 440 4.25crank-12.5 piston,not sure on cam yet. looking for input on which head would be better for my application like to get about 370 flow. indy seems to be the way. not sure about edelbrock but 325 out of box! thanks
Hell Hath No Fury Like Mine
Re: 440 ez heads or edelbrock victor max port?
[Re: sixpacksteve]
#1290235
08/23/12 07:55 PM
08/23/12 07:55 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I use the Indy EZ heads on my 493. They were worked a little and flow 330 @ .600. I wanted to stay with the stock rocker arm geometry and stock exh port location which the EZ head does. The Victor uses offset rockers and raised exh port so I believe it has more potential then the EZ heads for a strong build. I have never used the Indy Victor heads but I hear they are a good head. As for me I like how good the EZ heads are and can keep all the stock dimensions. Ron
[Re: sixpacksteve]
#1290238
08/24/12 06:59 AM
08/24/12 06:59 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The edelbrock have the offset rocker if I am not mistaken, which means they can ultimately flow more air. Typically the difference between the Indy small port and the big port with offset intake rockers is about 20 to 25 cfm. The bigger port window will make another 50 to 60 hp in a maxed out combo, but it requires an aggressive cam and more rpm to do it. I don't know how the big Edelbrocks stack up, but should be close to the 440-1 for power.
[Re: gregsdart]
#1290239
08/24/12 10:18 AM
08/24/12 10:18 AM
Posts: 83 Southern IL.
jafr
Southern IL.
In my opinion it depends on several factors, ie. what are you doing with the car, street car, drag car, what header you can fit, how heavy is the car, is this the biggest motor your going to build, what is the rest of the combination etc. Everyone wants to go for max flow, they forget about numbers accross the lift range. If it a street car you don't need a head that flows 370 at .750 lift unless you want to run a loose converter and a 4.56 gear on the street. You will need to run a pretty aggresive cam to take advantage of that type of cylinder head. I'm getting ready to buy a new set of 440-1s because I already have the oiling kit valley plate, rockers head studs, etc. and they will give me room to go bigger in the future. My car is a dragrace only tube chassis car. You might look at the Indy SR head also if you can deal with the raised exhaust port, better exhaust flow can be achieved than on the EZ head. A lot of people don't look at the exhaust flow just the intake.
[Re: jafr]
#1290240
08/25/12 12:11 AM
08/25/12 12:11 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
the car is drag only, i have 2"fenderwell headers hooker super comp just had the conv loosened up at ultimate 8" 5500 stall, 8 3/4 4:56 rear 9" drag radials. car weighs 2990 w/o driver. i'd like to go low 10's need input on which cam to use?
[Re: sixpacksteve]
#1290241
08/25/12 12:14 AM
08/25/12 12:14 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
the victor max claims to flow 330@700 out of the box!
[Re: sixpacksteve]
#1290243
08/25/12 01:17 AM
08/25/12 01:17 AM
Posts: 31,060 Oregon
AndyF
Read the 505 articles on my website. I used EZ heads a 266 at 050 roller cam. That engine made about 800 hp with a cast intake and a Dominator. That much power would push your car down the track just fine. www.arengineering.com then click on tech articles.
[Re: AndyF]
#1290244
08/25/12 09:21 AM
08/25/12 09:21 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i have the indy max intake w/1050 dominator which cam should i use?
[Re: sixpacksteve]
#1290246
08/25/12 09:56 AM
08/25/12 09:56 AM
Posts: 16,929 NC
440Jim
NC
A 500+ CID engine will be restricted by the Hooker A-body 2" fenderwell headers. They are just way too long to make peak hp. With high stall and 500+ CID at 3000 lbs you don't benefit from the 4000 rpm torque they make. Think about 2-1/8" (or stepped 2 to 2-1/8) that are only 30-34" long. Likely to get you 30hp peak improvement. And more if you RPM higher Quote:
Fast68plymouth dyno test, 493 CID Includes Hooker Super Comp A-body fenderwells (2" x 43") versus his dyno headers, stepped 2 to 2-1/8", 32" long (12" + 20")
test A-M1 4150/905 carb/1" open spacer/dyno headers
test B-M1 4150/1050 carb/2" adapter/dyno headers
test C-M1 4500/1050 carb/no spacer/dyno headers
test D-M1 4500/1050 carb/no spacer/ A body 2" headers
rpm---A/tq/hp----B/tq/hp-----C/tq/hp----D/tq/hp rpm--A/tq/hp-----B/tq/hp-----C/tq/hp----D/tq/hp 3700-----------------------------------------586/413 3800-----------------------------------------598/433 3900-----------------------------------------607/451 4000-521/397-----------------524/399---619/471 = +72 hp 4100-525/410---519/405----524/409---632/493 4200-555/444---533/426----545/436---631/505 4300-594/486---588/481----599/490---635/520 4400-605/507---594/498----617/517---636/532 4500-611/524---618/530----618/530---640/548 = +18 hp 4600-628/550---623/546----628/550---635/556 4700-632/565---634/567----630/564---635/568 = + 4 hp 4800-628/574---637/582----635/581---632/578 = - 3 hp 4900-630-587---632/589----634/592---626/584 5000-624/594---625/595----632/602---619/589 = -13 hp 5100-623/605---626/608----625/607---619/601 5200-617/611---622/616----624/618---612/606 5300-615/620---621/627----619/625---606/612 5400-609/626---620/637----609/626---599/616 5500-603/631---606/635----612/640---593/621 = -19 hp 5600-591/630---600/640----599/639---586/625 5700-587/637---600/651----597/648---578/627 5800-585/646---592/654----592/654---576/636 5900-578/649---589/661----584/656---560/629 6000-571/653---581/664----580/663---553/632 = -31 hp 6100-565/656---576/670----576/670---550/639 6200-557/658---567/669----560/661---538/635 6300-546/655---561/673----556/669---526/631 6400-541/660---549/669----544/663---516/629 6500-530/655---541/670----540/668---504/624 = -44 hp 6600-518/651---535/672----527/663---494/620 = -43 hp 6700-509/650---523/667----518/661---484/617 = -44 hp
[Re: 440Jim]
#1290247
08/25/12 11:59 AM
08/25/12 11:59 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
hey jim, what was the engine combo. heads,cam etc..
[Re: sixpacksteve]
#1290248
08/25/12 12:01 PM
08/25/12 12:01 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
will i need to reloosen the convertor, change rear gears higher?
[Re: sixpacksteve]
#1290249
08/25/12 12:02 PM
08/25/12 12:02 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
my engine builder recomends cam 750-800!
