did fury's come with DANA rear ends????
#1289975
08/23/12 09:04 AM
08/23/12 09:04 AM
Posts: 425 ne ohio
garymendy
ne ohio
Did fury's come with DANA rear ends and if they did, what is the conversion process to put them in a b-body?
also, what is a fair price for the whole rear end unit with axles diff and brakes etc????, again if it exists
is a 9 1/4 the same as a DANA???
Thanks for any help on this
Re: did fury's come with DANA rear ends????
[Re: garymendy]
#1289976
08/23/12 09:06 AM
08/23/12 09:06 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Not that I can remember and no they are not the same.
[Re: Rhinodart]
#1289978
08/23/12 09:39 AM
08/23/12 09:39 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Wasn't there a special Dana rear used in the mid 60's Fury's and Polara's? Like a Dana 50 or something?
That would be correct,67 and possibly 68,4spd only and they will bolt right in an early B-body.Available with 3.31 or 3.73 gears,Dana Power Lock ,10 bolt cover.They are rare.
[Re: Commando1]
#1289982
08/23/12 02:46 PM
08/23/12 02:46 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
Actually a Dana 53 that had a 9.25 ring gear and only used in 440 4 spd cars IIRC
Congratulations. You nailed it exactly. We have a winner.
I believe a 67 C Body with a factory towing package would also have a D53.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: EWJ]
#1289983
08/23/12 05:24 PM
08/23/12 05:24 PM
62maxwgn
Blair County,PA
A little curious now.The rear I have came out of a 66 Hemi Belvedere that was raced on a dirt track in Selinsgrove,PA back in the early 70's.Ring gear is dated 4/10/66,kind of early for a 67 model year vehicle,housing has 44" spring pad location and the housing was never modified,10" brakes,wheel cylinders were original with Chrysler casting numbers,flange U bolt not strap.Bolted right into my 62 Savoy wagon. Could there have been other limited applications ? Couk
[Re: 62maxwgn]
#1289984
08/23/12 07:18 PM
08/23/12 07:18 PM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
I looked in a HOLLANDER book I have & typed all the part numbers and components, but it disappeared when I hit "submit". 3.31:1 ONLY Note: ring gear diameter is 9-1/4" Chrysler '67 non-removable carrier Dodge pass '67-'68 Polara & Monaco non-removable carrier Plymouth pass '67-'68 Fury & VIP non-removable carrier
[Re: 6bblgt]
#1289986
08/23/12 08:59 PM
08/23/12 08:59 PM
62maxwgn
Blair County,PA
That is what it is supposed to be but the one I have fits an early b-body without any modifications,the above won't.
