did fury's come with DANA rear ends???? #1289975
08/23/12 09:04 AM
08/23/12 09:04 AM
ne ohio
garymendy Offline OP
ne ohio
Did fury's come with DANA rear ends and if they did, what is the conversion process to put them in a b-body?
also, what is a fair price for the whole rear end unit with axles diff and brakes etc????, again if it exists
is a 9 1/4 the same as a DANA???
Thanks for any help on this
Re: did fury's come with DANA rear ends???? [Re: garymendy] #1289976
08/23/12 09:06 AM
08/23/12 09:06 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Not that I can remember and no they are not the same.
Re: did fury's come with DANA rear ends???? [Re: MoparforLife] #1289977
08/23/12 09:32 AM
08/23/12 09:32 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Wasn't there a special Dana rear used in the mid 60's Fury's and Polara's? Like a Dana 50 or something?
JB Rhinehart, Realist
A-Body's RULE!
Re: did fury's come with DANA rear ends???? [Re: Rhinodart] #1289978
08/23/12 09:39 AM
08/23/12 09:39 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
That would be correct,67 and possibly 68,4spd only and they will bolt right in an early B-body.Available with 3.31 or 3.73 gears,Dana Power Lock ,10 bolt cover.They are rare.
Re: did fury's come with DANA rear ends???? [Re: 62maxwgn] #1289979
08/23/12 12:08 PM
08/23/12 12:08 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Actually a Dana 53 that had a 9.25 ring gear and only used in 440 4 spd cars IIRC
Re: did fury's come with DANA rear ends???? [Re: 446acuda] #1289980
08/23/12 12:26 PM
08/23/12 12:26 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Congratulations. You nailed it exactly.
We have a winner.
Re: did fury's come with DANA rear ends???? [Re: Commando1] #1289981
08/23/12 12:34 PM
08/23/12 12:34 PM
ALBERTA CANADA
furydave Offline
furydave  Offline
ALBERTA CANADA
If the car still exsists with the dana 53 it has to be a 440 4 speed C body. whats it coming out of any pics???? very very rare. save it.
I have one in my 68 sport fury 440 4speed rag.
Re: did fury's come with DANA rear ends???? [Re: Commando1] #1289982
08/23/12 02:46 PM
08/23/12 02:46 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
We have a winner.
I believe a 67 C Body with a factory towing package would also have a D53.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: did fury's come with DANA rear ends???? [Re: EWJ] #1289983
08/23/12 05:24 PM
08/23/12 05:24 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
A little curious now.The rear I have came out of a 66 Hemi Belvedere that was raced on a dirt track in Selinsgrove,PA back in the early 70's.Ring gear is dated 4/10/66,kind of early for a 67 model year vehicle,housing has 44" spring pad location and the housing was never modified,10" brakes,wheel cylinders were original with Chrysler casting numbers,flange U bolt not strap.Bolted right into my 62 Savoy wagon.
Could there have been other limited applications ?
Couk
Re: did fury's come with DANA rear ends???? [Re: 62maxwgn] #1289984
08/23/12 07:18 PM
08/23/12 07:18 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I looked in a HOLLANDER book I have & typed all the part numbers and components, but it disappeared when I hit "submit".
3.31:1 ONLY
Note: ring gear diameter is 9-1/4"
Chrysler '67 non-removable carrier
Dodge pass '67-'68 Polara & Monaco non-removable carrier
Plymouth pass '67-'68 Fury & VIP non-removable carrier
Re: did fury's come with DANA rear ends???? [Re: 6bblgt] #1289985
08/23/12 08:07 PM
08/23/12 08:07 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I have an NOS C-body Dana 53 housing. It takes the same pinion snubber as a passenger car Dana 60.
Re: did fury's come with DANA rear ends???? [Re: 6bblgt] #1289986
08/23/12 08:59 PM
08/23/12 08:59 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
3.31:1 ONLY
That is what it is supposed to be but the one I have fits an early b-body without any modifications,the above won't.
