Back to square one
#1289884
08/23/12 12:07 AM
08/23/12 12:07 AM
Posts: 261 Eastern ohio
Alexdodge
Eastern ohio
After installing a comp cam- 268,edlebrock aluninum intake and a 600 eddy carb on the 361 I have the problem of not being able to get the engine to a decent idle speed. The engine in running at about 850 rpms to keep it running. At this rpm it sounds good but when I put it in drive, the engine barely wants to run,like its only running on a couple cylinders. When I close off the carb intake with my hands the rpms actually increase. I have since installed a new pan gasket with the .015 gaskets on each side of the pan with sealant. This has had no effects at all. I sprayed starting fluid all around the intake and carb with no effects. Checked all hoses and fittings, OK I cannot hear any sound of air being sucked in anywhere. I drove the car around with this problem and the timing set to 10 btdc. After I pulled out all the plugs and they were all a nice white-grey color. I have been fooling with this thing for 3 weeks now and am totally disgusted. I'm in dire need of more help. Where do I go from here? Alex in eastern ohio
Re: Back to square one
[Re: Alexdodge]
#1289885
08/23/12 12:12 AM
08/23/12 12:12 AM
RapidRobert
it ran OK before the swap? You swapped the cam/intake/carb & no other changes? EDIT It sure sounds like a vac leak though
[Re: Alexdodge]
#1289887
08/23/12 01:52 AM
08/23/12 01:52 AM
Posts: 4,848 Memphis
HemiRick
Memphis
I had same cam in a 440 and had the same issue. I tried with no luck to modify the carb on it to work. Eventually I swapped carbs and found one that the engine liked. Out of 3 carbs I tried it only liked that one. So even though I didnt really want to use that carb on that engine, I went with it.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: buildanother]
#1289889
08/23/12 03:15 AM
08/23/12 03:15 AM
Posts: 43,233 Bend,OR USA
Cab_Burge
Try a little more initial advance. If the torque converter is stock stall, it may need a higher stall.
OP,you may or probally need to shorten up the mechanical advance in the distributor so you can run more intital timing, like 14 to 18 degrees BTDC at idle It wouldn't suprise me that you have the timing falling back when you put in gear, put a light on it in nuetral and then have someone put it in gear without touching the throttle, see if it is retarding back more in gear
[Re: Cab_Burge]
#1289890
08/23/12 04:35 AM
08/23/12 04:35 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Do you have the proper spacer/gasket/adapter under the carb?
What happens when you put your hands over the carb inlet? Did you degree the cam or install it dot to dot ? Im betting on a vac leak under the carb...
I am truckless..
[Re: 340SHORTY]
#1289891
08/23/12 09:50 AM
08/23/12 09:50 AM
Alexdodge
Eastern ohio
The cam was set up dot to dot. I do have a new eddy 800 carb here but I thought that would be too large for a 361. Should I try it anyway? Like I said, I have sprayed starting fluid everywhere and had no results. I do have a fiber spacer under the carb with gaskets. Is there more than one dot on the timing gear maybe that I could have missed? I will try putting the car in gear and rechecking the timing to see if it drops back. I have no idea how to recurve the distributor if it comes to that. Alex
[Re: Alexdodge]
#1289893
08/23/12 11:23 AM
08/23/12 11:23 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
800 is not too big for a 361 (mother put 800 thermo Bogs on 318's) You have to find that vacuum leak. All plugs on front and back of carb? BB intakes often leak air underneath. Vacuum advance on ported vacuum or better plugged for now. (it is only supposed to work at light throttle highway cruise) Then My guess is is that the cam is not in right! did you roll over and check and check again after installing it??? often what looks right especially down in the car looks right but becomes obvious it's wrong if you turn a few times. So if you a tooth off and the carb is turned way open to get idle up idle circuit will not work so it's lean! covering with hands can make a difference. next even dot to dot todays cams and timing sets can be so far off they will not run right. Just degreed a cam in a 383 with a mancini timing set that was retared 8 deg's dot to dot!
[Re: CUDAJAS]
#1289895
08/23/12 01:07 PM
08/23/12 01:07 PM
Alexdodge
Eastern ohio
OK, now here is what I did. First thing is replaced the 600 with the 800 eddy. This was a great beginning. Now the car will idle and die quickly when I block the air inlet! I set the timing to 18* btdc. While in park and it stayed on solid. Then I checked the timing with the engine in drive and saw that the timing mark was jumping everywhere. From the 18^ to 0^ to 40^ or more. But it didn't seem to make the rpms bounce. I set the rpms to 700 in park and when I put it in drive it went to a solid 600. Do I still have a problem? Also I wish I understood why the 600 would not work correctly on this motor, but thats another story I guess. So guys what is with the timing mark jumping everywhere in drive. Or is this normal. Alex Thanks to you folks I'm getting closer to having it on the road again. Please keep the ideas coming!
[Re: Dodgem]
#1289897
08/23/12 01:58 PM
08/23/12 01:58 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Check the top bushing in your distributor sounds to me like the distributor is worn out??
that would be my guess as well
[Re: Alexdodge]
#1289900
08/23/12 02:14 PM
08/23/12 02:14 PM
mikemee1331
bethlehem pa
Even though the marks are solid when in park???
yes, the higher the rpm's the more amplified the slop becomes. sorta like a pully with a slight twist in it. low rpm's it's fine but the faster it spins the more pronounced the 'wobble' and it starts tearing or throwing belts.
