Re: Stroker Motors and 6 packs: what are the tricks? [Re: Big Squeeze] #1289701
08/26/12 10:16 AM
08/26/12 10:16 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Heres the big block Solution :
Bob k secret camshaft, maybe hes got simething
Up his sleeve for small blocks
505 stroke 500 hp dyno sheet ,
Idles like a vw and made 16-20" hg
At idle
Re: Stroker Motors and 6 packs: what are the tricks? [Re: Streetwize] #1289702
08/26/12 11:00 AM
08/26/12 11:00 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
The beauty of 6paks for me was being able to change out vacuum diapragms within minutes ( i always used the quick change kits) and actually be able to tweak at the track for traction conditions.
will the 4bbl quick change diaphragms fit/work on 2300's or is there a specific QCD for them?
Re: Stroker Motors and 6 packs: what are the tricks? [Re: Mr340] #1289703
08/26/12 11:53 AM
08/26/12 11:53 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Dudes,
Did anybody see this little jewel in the Tech Archives??
http://www.moparts.org/Tech/Archive/fuel/7.html
WIZE
In Car:
Re: Stroker Motors and 6 packs: what are the tricks? [Re: AlexP] #1289704
08/26/12 01:41 PM
08/26/12 01:41 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I found the six-pack carbs don't like high fuel pressure. Originally we could not get the outer carb fuel levels to stay set. Found we had 9-psi fuel pressure and the float arms were bending on the outer floats that had the black plastic type floats. The brass center float did not seem to have this problem. Pressure regulator adjustment was the solution for that problem.
With the larger stroker engine and cam, make sure you are not into the transfer slots at idle.
If the idle mixture is too lean, you may have to open up the idle restrictor, this should also richen up the transition circuit which will help with off idle hesitation. As mentioned, you may need stiffer vacuum springs on the outboard carbs.
Re: Stroker Motors and 6 packs: what are the tricks? [Re: Big Squeeze] #1289705
08/26/12 08:58 PM
08/26/12 08:58 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Your post a few months ago on your 6 pac tuning experience is probably the best that I've read anywhere. Your thoughtful changes and associated data collection displays very well the causes and effects that support the results quite logically. It shows nicely the interrelated aspects of the 6 pac in about as simple of a way as possible.
Re: Stroker Motors and 6 packs: what are the tricks? [Re: BSB67] #1289706
08/27/12 01:54 AM
08/27/12 01:54 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Well, thanks..... I figured that thread had already been totally forgotten about.......
I still learn something about tuning every day......
If you can't handle the truth, you're living a lie.......
Re: Stroker Motors and 6 packs: what are the tricks? [Re: Big Squeeze] #1289707
08/27/12 10:02 AM
08/27/12 10:02 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
What's an A/F meter?
Coming soon!!!!
Re: Stroker Motors and 6 packs: what are the tricks? [Re: Mr.Yuck] #1289708
08/27/12 10:07 AM
08/27/12 10:07 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Small electrodes that say "Champion" on them...
Re: Stroker Motors and 6 packs: what are the tricks? [Re: Dragula] #1289709
08/27/12 07:19 PM
08/27/12 07:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Mine say NGK will that work?
Re: Stroker Motors and 6 packs: what are the tricks? [Re: Mr.Yuck] #1289710
08/27/12 09:50 PM
08/27/12 09:50 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Reading spark plugs to tune driveability instead of using an O2 sensor is like bouncing a wooden bat off your tires to check tire pressure instead of using a tire pressure gauge.........
Re: Stroker Motors and 6 packs: what are the tricks? [Re: Big Squeeze] #1289711
08/27/12 09:58 PM
08/27/12 09:58 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Ask Jake King, or Maurice Petty about that 'wooden bat'...
'Sensor' is subjective...They didn't all have dials...
Re: Stroker Motors and 6 packs: what are the tricks? [Re: RSNOMO] #1289712
08/27/12 10:04 PM
08/27/12 10:04 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
I've seen truck driver's get pretty close with a bat while checking tire pressure, that's why I said that...
