Re: Need help with Edelbrock tuning
[Re: Beep Beep]
#1289393
08/22/12 12:31 AM
08/22/12 12:31 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
change metering rods to part# 1446 91 octane sux also
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Beep Beep]
#1289396
08/22/12 06:23 PM
08/22/12 06:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You need to fatten up WOT. might be able to go leaner on cruise.
Just remember one thing, your idle setting will affect all other settings too.
You will only be able to find out what your setup runs best on by testing and tuning.
[Re: Supercuda]
#1289397
08/22/12 07:19 PM
08/22/12 07:19 PM
Challenger 1
Cincinnati, Ohio
You will only be able to find out what your setup runs best on by testing and tuning .
Don't be afraid to touch it, the car that is.
[Re: Challenger 1]
#1289398
08/22/12 10:08 PM
08/22/12 10:08 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
TAKE NOTES!
You're sitting pretty good now. Write down the settings you have. That way if your changes don't work out (or don't work out as the weather changes) you know what the previous settings were.
