Need help with Edelbrock tuning #1289392
08/21/12 11:55 PM
08/21/12 11:55 PM
NY
Beep Beep Offline OP
NY
I am trying to tune my 500 cubic inch street driven motor. I installed a air fuel gauge to help with tuning. These are my results.
71 f ambient on 91 octane with no ethanol
Idle range is 13.8 to 14.2
Cruise range on the highway is 13.9 to 14.1
Wot range is 12.8 to 13.0
I am running an Edelbrock 1813 AVS. I get the occasional very small ping under wot. I am going to try pulling the timing back to 32 from 34. I would like to see the wot 12.5 but not sure were to start.
Re: Need help with Edelbrock tuning [Re: Beep Beep] #1289393
08/22/12 12:31 AM
08/22/12 12:31 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
change metering rods to part# 1446
91 octane sux also
Re: Need help with Edelbrock tuning [Re: Beep Beep] #1289394
08/22/12 12:40 AM
08/22/12 12:40 AM
San Jose, Ca.
dhkennedy Offline
dhkennedy  Offline
San Jose, Ca.
I run the FAST EZ EFI on a mild 440 and your AFR is leaner than what I run. Idle 13.6, cruze 13.8, WOT 12.6.
Re: Need help with Edelbrock tuning [Re: dhkennedy] #1289395
08/22/12 06:17 PM
08/22/12 06:17 PM
NY
NY
Thanks guys, how does the idle and cruise look. What values am I looking for idle,cruise and wot?
Re: Need help with Edelbrock tuning [Re: Beep Beep] #1289396
08/22/12 06:23 PM
08/22/12 06:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You need to fatten up WOT. might be able to go leaner on cruise.
Just remember one thing, your idle setting will affect all other settings too.
You will only be able to find out what your setup runs best on by testing and tuning.
Don't be the exception.
Re: Need help with Edelbrock tuning [Re: Supercuda] #1289397
08/22/12 07:19 PM
08/22/12 07:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You will only be able to find out what your setup runs best on by testing and tuning .
Don't be afraid to touch it, the car that is.
Re: Need help with Edelbrock tuning [Re: Challenger 1] #1289398
08/22/12 10:08 PM
08/22/12 10:08 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
TAKE NOTES!
You're sitting pretty good now. Write down the settings you have. That way if your changes don't work out (or don't work out as the weather changes) you know what the previous settings were.
- Stu Harmon
Re: Need help with Edelbrock tuning [Re: feets] #1289399
08/22/12 10:56 PM
08/22/12 10:56 PM
NY
NY
I took it for a drive tonight and without changing anything I am getting:
idle: 14.0 - 14.2
cruise: 14.4-15.0
wot:12.7-13.0
I did notice that when the cruise was up to 15.0 you could just slightly feel it starting to hesitate a small amount. When I leave a stop you also feel it lean out for a split second. I seen the a/f go to 22.0 then back to roughly 14.0. Also when you are in cruise and you slightly lean into the throttle it will go lean up to 16.0 then back to 14.0 within a second. I may have to change the metering springs. My readings have changed a small amount, could be due to the weather. Ambient was 72f. I guess the density of the air and RH will affect it also. I ordered the metering rods.
