Re: Best place to order 440-1 heads from
[Re: domingo]
#1289236
08/21/12 07:21 PM
08/21/12 07:21 PM
Posts: 4,676 On the parachute mount
n20mstr
contact Scott Brown....Buyracingparts.com
He can do the heads very nice and also sells T&D rockers
....BAD A$$ STREET CAR.....
[Re: Ari440]
#1289242
08/21/12 09:49 PM
08/21/12 09:49 PM
Posts: 903 Saskatchewan, Canada
cudabin
Jeff at Modern Cylinder Head has a great CNC porting progra for the -1 heads and he is good to work with. His 345cc CNC port job made 955hp on my 557ci Kieth Black motor. He will also correct Indy's mistakes... Good luck, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: Cab_Burge]
#1289246
08/22/12 10:39 AM
08/22/12 10:39 AM
BradH
I called Dwayne originally about CNC porting my Eddy RPM and he said to call Jeff at Modern CCylinder Heads
That's because Dwayne doesn't offer a CNC program for anything but Indy heads. Makes sense to me...
Another vote here for Dwayne Porter as your Go To person for prepped Indy heads.
[Re: BradH]
#1289247
08/22/12 11:16 AM
08/22/12 11:16 AM
Posts: 901 oh
julian2007
oh
Best Machine Race Engines, CHUCK MILLEN OR PETE COSTA very good mopar guys, built my 588 and it freeking flys They are a Indy dealer There number is 248-987-6038
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
[Re: bonefish]
#1289249
08/22/12 12:13 PM
08/22/12 12:13 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
Another vote for Dwayne Porter If I didn't get the 'offer I couldn't refuse' on My Chapman Maxies I would have done a set of 'Porter-1's' on my 517. If you're doing a pump gasser a higher velocity port (same CFM but smaller cross section for better part throttle torque) might work better than the -1, it really depends on your combo and where you want the powerband to go. Of course there's no doubt a well ported -1's will make MAD power and torque but on pump gas and more streetable cam timing you might produce a broader average torque curve with a 'faster' port that has more velocity down low and through the middle.
[Re: Brian Hafliger]
#1289254
08/23/12 01:35 AM
08/23/12 01:35 AM
cudabin
Hey everyone, Brian (OU812)is good people... I have bought a cam and a couple sets of lifters from Brian and he took the time to really think through the specs. The result was a 9.50 with my old 470 stock block motor in the Cuda. Cheers, Arnie
