Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: moparmarks] #1289190
08/30/12 01:49 PM
08/30/12 01:49 PM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
Same Wagner rotor, different price:
http://www.rockauto.com/catalog/x,carcode,1440922,parttype,1896
http://www.jegs.com/i/Wagner/436/BD60418/10002/-1
Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: Jeremiah] #1289191
10/17/12 06:41 PM
10/17/12 06:41 PM
California
Mad Dart Offline
Mad Dart  Offline
California
The rotorpros stuff is nice! About $180 slotted and drilled shipping included.
Thanks for the heads up. DId you install the 3" Studs or did they do them? I am doing the same set up on my 67 Dart right now. Putting the K Frame together.
If anyone else is interested.
http://rotorpros.net
Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: Mad Dart] #1289192
10/18/12 01:04 AM
10/18/12 01:04 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I installed the 3" Moroso studs in my press here at the shop. It can be tough to get them in perfectly straight so be careful when you press them in or take them to someone that knows how to do things right the first time (aka not the tire shop).
If you need the p/n for the studs I can dig a little and get it for you.
Edit: I see you are in CA. If you are far enough North you are welcome to bring your rotors by and we can press the studs in at my little shop.
Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: Jeremiah] #1289193
10/18/12 07:48 PM
10/18/12 07:48 PM
California
Mad Dart Offline
Mad Dart  Offline
California
Thanks for the information and offer to press them in. I am in Southern California 60 miles north of San Diego. If you can get the part number for the studs, I would appreciate it.
I just ordered the complete set up this morning. Wilwood Dynalite Calipers, Pads, Mancini Caliper Adapters brackets for 11.75 Rotors & the Rotors from rotorpros.net The Rotors were $140.00 Shipped to my door Slotted and Drilled. There is a guy on ebay selling the same thing for $275.00 and he says he is 3 weeks on lead time. I was promised the rotors next day delivery so I should have them tomorrow.
Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: Mad Dart] #1289194
10/19/12 01:00 PM
10/19/12 01:00 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Are you also getting the DrDiff bearing adapters so that you can use the 11.75 rotors on your '72 spindles? I'm curious as to the life of the DD bearing adapters as well as their accuracy in allowing the larger bearings needed for 11.75 rotor setup.... I'm deciding to eventually install the 11.75 rotor setup but my spindles have the smaller bearings.... seems to be a major hassle to obtain and remove/install the '73-up spindles... also... i'd get the drilled/slotted rotors as I'm gradually doing more hi-speed track events vs low-speed autocross.
Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: Mopar Mitch] #1289195
10/19/12 01:49 PM
10/19/12 01:49 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Bearing sleeves which not overly common are used in some heavy industrial applications so I wouldn't expect them to create any problems in the spindle application...
Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: Mopar Mitch] #1289196
10/19/12 09:42 PM
10/19/12 09:42 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have been running the Dr Diff bearing sleeves on our '66 Charger for a few months and a few thousand miles. When/if I switch to winter tires (studded) I will check the front breaks/bearings and report back on this. So far everything feels good. The reason I say "if" is because the car is for sale.
Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: Jeremiah] #1289197
10/19/12 11:22 PM
10/19/12 11:22 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
What kind of tie rod sleeves and strut rods? Looks nice.Hows the ride?
Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: pro451bee] #1289198
10/20/12 12:32 AM
10/20/12 12:32 AM
central CT
cudazappa Offline
cudazappa  Offline
central CT
2 years on my dr diff bearing adapters. Am probably taking them off because my Baer brakes will use my stock spindles. My main reason for upgrading was for affordable selection of different pad compounds.
1971 Challenger
Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: pro451bee] #1289199
10/20/12 01:13 AM
10/20/12 01:13 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
The sleeves are PST and the strut rods are RMS. Both parts are very nice for the money. The ride is good however the red car is a more drag oriented ride utilizing all of those nice parts to lighten it up and provide lots of suspension travel for good weight transfer. It has 3.5" front wheels and M&H drag radials on the back to it feels pretty scary compared to a car with regular tires. It drives about as good as it did with stock parts due to the tires being the limiting factor.
My other '66 Charger (white-ish in color) is the one with the 70-72 b-body spindles and 73-up rotors/calipers. If it does not sell it will be next in line for the same modifications minus the strut rods because I drive it in the winter (no road salt here).
Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: Jeremiah] #1289200
10/20/12 06:18 PM
10/20/12 06:18 PM
California
Mad Dart Offline
Mad Dart  Offline
California
I am using the 73 Up spindles. I also used the stock 6 cylinder K frame and adapted it for my Twin Turbo application along with boxing and welding the complete K Frame off and converting the Idler arm over to the Less Expensive 73 and up version. Also did a coil over conversion and tied everything into a 14pt cage.
Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: Mad Dart] #1289201
10/20/12 06:22 PM
10/20/12 06:22 PM
California
Mad Dart Offline
Mad Dart  Offline
California
Some pics.
Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: Mad Dart] #1289202
10/20/12 06:23 PM
10/20/12 06:23 PM
California
Mad Dart Offline
Mad Dart  Offline
California
pic
Re: Do 1972 b-body spindles fit a 1970 B-body? [Re: Mad Dart] #1289203
10/20/12 06:26 PM
10/20/12 06:26 PM
California
Mad Dart Offline
Mad Dart  Offline
California
