Page 1 of 4 1 2 3 4
HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? #1288922
08/21/12 12:49 AM
08/21/12 12:49 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
...In a 3720 lb. "race weight"(with driver)GTX? The Wallace Calculator is not even close to the MP listing,in my Mopar Performance manual! ALL educated guesstimates are welcome! Fastest the car has gone is a 11.19 @ 120 mph. Thanks in advance for your info! Randy B.
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288923
08/21/12 12:56 AM
08/21/12 12:56 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I'll guess 525rwhp.
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288924
08/21/12 01:06 AM
08/21/12 01:06 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Randy here is what the moparts said my car should be making. But it says i should of ran a 10.90 in the 1/4 with (Your Rear Wheel Hp Is: 533.52) but in the cool fall air i ran a best of 10.68. So i don't know how right the program is. mopar65 :beer
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: RobX4406] #1288925
08/21/12 01:12 AM
08/21/12 01:12 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
675 flywheel according to my calc will get you 10.81 @ 124.5 at 3720 lbs.
Kevin
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: mopar65] #1288926
08/21/12 01:14 AM
08/21/12 01:14 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Hi,Bobby! It says with my best of 120mph at 3720...it's making 502 at the rear wheels. Not sure what that translate to at the crank? On Gary Jacob's dyno,it made 425 at the wheels! That's a big difference!
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: mopar65] #1288927
08/21/12 01:15 AM
08/21/12 01:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That thing is way off... the numbers it says for
RWHP is close to flywheel but then its still off
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288928
08/21/12 01:23 AM
08/21/12 01:23 AM
My original 512 C.I. pump gas low deck made 612 HP at 5600 RPM and 644 Ft lbs at 4500 RPM. It ran 10.69 ET at 124.6 MPH at Woodburn corked up with the air cleaner on the six pak. That was with me in it weighing close to 3400 Lbs. wet, corked up with the air cleaner on, 4.10 gears with 30 inch tall tires The torque converter can and does makes a huge difference on our cars I ran the car at Woodburn several times this summer, it ran 9.96 at 134 MPH corked up on pump gas. This motor made 727 HP the last time it was on a DTS engine dyno at 4300 Ft elevation in Klamath Falls, OR I broke my ten inch custom built converter two years ago, I put in a new T/A 8 inch race Hemi converter with no other changes, it made the car way easier to drive and race and pick my car up .2 ET and 2 MPH in the 1/8 mile
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Cab_Burge] #1288929
08/21/12 01:31 AM
08/21/12 01:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The few times I have run my #'s on a program they all seem to be close as it says I make about 600 to 625 at the flywheel to run 10.70's at just over 3700 lbs. Ron
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288930
08/21/12 01:53 AM
08/21/12 01:53 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
570fwhp.
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: goldmember] #1288931
08/21/12 02:00 AM
08/21/12 02:00 AM
SoCal
Brian Hafliger Offline
SoCal
570fwhp.
Bingo! My duster with a 560HP 360 went 10.50's-10.60's at 127mph at 3360lbs. with me in it.
Just remember, engine acceleration is just as important as the HP and TQ the engine produces!!
Brian
Brian Hafliger
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: 383man] #1288932
08/21/12 02:00 AM
08/21/12 02:00 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
I have made 468 - 500 at the rear wheels on different dynos ..but I have gone 10.67 at 125 with a racing exhaust and 4.10 gears.. to slow the car down I put 3.73's in and my full exhaust and MT drag radials and the car went ....10.67 at 122 lol at 3750 with me ....you should see your first 10 !!!! at Norwalk and then some
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: RobX4406] #1288933
08/21/12 02:00 AM
08/21/12 02:00 AM
SoCal
SoCal
I'll guess 525rwhp.
Yep, this too!
Brian Hafliger
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: 10secGTX] #1288934
08/21/12 02:08 AM
08/21/12 02:08 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Yep about 470 rwhp(570fwhp-18%=470ish) would do it!Its simple math,not rocket science.
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: RobX4406] #1288935
08/21/12 02:11 AM
08/21/12 02:11 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'll guess 525rwhp.
I'd say 10.50's with that number.
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: goldmember] #1288936
08/21/12 02:45 AM
08/21/12 02:45 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Randy,
my Satellite on the dyno normally shows 405-410RWHP.
Best et is 11.09 normally runs .12-16 MPH is around 118.9-119.75
car weight last time weighed is around 3775lbs
i have a 5200 stall and with any stall you won't see a true hp.i will normally look at adding 15% puts it in the real ballpark.Means about 525-535FWHP
around 20-25HP should give you a tenth.If you get around 100FWHP over me you may exceed your hopes
good luck
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: tex013] #1288937
08/21/12 04:43 AM
08/21/12 04:43 AM
Oh
His and Her 69's Offline
Oh
Randy our RR weighs 3700 with driver and with 615 hp on the dyno it ran 10.80's with street tires and exhaust to the rearend. It was no way all scienced out so I am sure it could have gone faster. It has a J conv, a 4.10 sure grip dana 60, full interior, etc.
The car usually ran 11.0's to 10.90's in normal air and cooler air it was faster. The 60' times were slow at 1.58 best but normal was 1.64's most of the time.
David
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: His and Her 69's] #1288938
08/21/12 09:25 AM
08/21/12 09:25 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks everyone! Fran..you will see me at Norwalk..but not the GTX! I still have a ways to go until it's completely re-assembled. Motor should be ready for the Stuska engine dyno shortly. I'm hoping for a "nice" little horsepower increase from Jeff's cnc-porting..and milling the Eddy's for a bump in compression..from 10:1 to 11:1. The heads were box-stock,port and combustion chamber-wise,with Isky 8005 springs,and Comp retainers. I'm guessing the heads flowed 275-280cfm,at best. They now flow 322 on the intake..and 223 on the exhaust,at .650 lift. My Comp solid flat tappet has .614/.620 net lift. So I'll probably see closer to 318/222. I've been told I SHOULD see an increase of approx. 80-100hp. If that's the case I SHOULD(BIG 6 LETTER WORD!)see 525rwhp..or close to it! I'll soon find out! Thanks again,EVERYONE! Randy
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288939
08/21/12 09:42 AM
08/21/12 09:42 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
It will be interesting to see what it makes for power and what it runs. Mine is very similar at 3750 lbs. with me in it and runs a best of 10.63 @ 126 and normally runs 10.69 to 10.73. I have never had it on a dyno.
67' charger 499 RB 10.57 at 127
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: dragram440] #1288940
08/21/12 09:49 AM
08/21/12 09:49 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Matt...GREAT running Charger! My GTX HATES Drag Radial street tires!....tried my 295/65R-15's at the track once...can't get it to hook with them! I think my best 60' was a 1.72!
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288941
08/21/12 09:59 AM
08/21/12 09:59 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I normally run 28 x 14.50 Hoosier Quick time pro's I just ran the 275 60 Drag radials for a weekend but they did work good for me. My car is basically all stock 45 year old leaf springs some inexspensive gas shocks. It has a best 60' of 1.49 which Im sure could get better with some better suspesion parts. I was guessing mine makes 650 to the flywheel but could be off.
Page 1 of 4 1 2 3 4
