Removing alternator pulley #1288829
08/20/12 10:37 PM
08/20/12 10:37 PM
Mooresville, NC
A70Runner Offline OP
Mooresville, NC
I bought March Pulleys for my engine but can't figure out how to get the alternator pully off to change it. I don't want to mess it up.
How does it come off? Any special tools/tricks?
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: Removing alternator pulley [Re: A70Runner] #1288830
08/20/12 10:42 PM
08/20/12 10:42 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You need one of these.
Re: Removing alternator pulley [Re: A70Runner] #1288831
08/20/12 11:05 PM
08/20/12 11:05 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I can ship it to you to borrow if you want to pay the shipping there and back
Gus
64 Plymouth Savoy
Dana 60
Re: Removing alternator pulley [Re: A70Runner] #1288832
08/20/12 11:21 PM
08/20/12 11:21 PM
As said you need the tool. then seperate the alt case & take the front half in to have the March pulley pressed on. Make magic marker marks on the 3 sections to easily go back together with the correct clocking
Re: Removing alternator pulley [Re: RapidRobert] #1288833
08/21/12 09:20 AM
08/21/12 09:20 AM
WV
JohnH Offline
JohnH  Offline
WV
When you go to reinstall the pulley make sure you have the rear of the shaft on a solid peice of iron when you tap the pulley back on or you will drive the shaft thru the armature.
Re: Removing alternator pulley [Re: fourgearsavoy] #1288834
08/21/12 09:25 AM
08/21/12 09:25 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
Gus
that tool is about $20 at Harbor Freight.
http://www.harborfreight.com/automotive-pulley-puller-66868.html
perception is 90% of reality
Re: Removing alternator pulley [Re: Mr T2U] #1288835
08/21/12 09:31 AM
08/21/12 09:31 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A parts store might have that puller too, just use a hose clamp around the jaws to help hold then in tight.
Don't be the exception.
