Dual Quad vs. Single Carb
#1288747
08/20/12 08:17 PM
08/20/12 08:17 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
I have been running a dual quad setup (Eddy 600's) on my Charger for a long time with no real problems. It's a basically stockish 440; Stealth heads, .030 over, 282/292, .465/.488 cam, shorty headers, 4-speed. It's been very reliable and maintenance free.
I'm wondering what real improvement in performance I would get with a correctly set up single carb. I noticed on my buddy's '68 440 Charger with a single Holley, it really has great throttle response and power.
I really like the visual impact of the dual quad at shows and such, but am I leaving a lot of power on the table?
Opinions?
Re: Dual Quad vs. Single Carb
[Re: Cudajon]
#1288753
08/21/12 09:58 PM
08/21/12 09:58 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Generally speaking on a street engine a good single 4 will trump the duals in HP and drivability, but as stated, lack the visiual appeal of dual 4's. That said, regardless of it being a big block or small block, if it's 500 cubes or less and a true pump gas street engine and you want the most from a set of dual 4's buy the smallest cfm carbs available from the desired brand (Holley, Carter, etc.) and start from there, you'll likely find that you'll get the best throttle response, milage, and overall performance.
[Re: ScottSmith_Harms]
#1288756
08/22/12 07:05 AM
08/22/12 07:05 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
A 605 Hemi is entirely different story!
Doesn't make a difference if it's a 605 or a 440. PROPERLY TUNED is what makes the difference. Most people are usually to lazy to go through all the work to get them right. Dave ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: quickd100]
#1288757
08/22/12 07:38 AM
08/22/12 07:38 AM
Posts: 4,794 Holland MI Ottawa
2boltmain
Holland MI Ottawa
On a 440 the Edelbrock is much better than the Offenhauser. The Edelbrock properly tuned will be hard to beat on a street vehicle-real world street driving. I believe the rpm range as stated from Edelbrock is idle to 6000Rpm with 2 of their carbs.
Keep old mopars alive.
[Re: quickd100]
#1288758
08/22/12 09:28 AM
08/22/12 09:28 AM
Posts: 12,419 Taxes & Virus's R-US, NY
Dragula
X2
It takes time to get carbs correct, and I find most people can't even read plugs, so how can you tune a carb without an A/F meter if you can't read plugs? Not to mention today's unleaded contains 10% ethanol, which means, if you haven't richened your mixture since running it, your off for the A/F the newer fuel wants. Its not 12.8:1 at WOT anymore....
[Re: Dragula]
#1288759
08/22/12 10:18 AM
08/22/12 10:18 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't dissagree with you on that, my point was that for the average street engine (500 cubes or smaller) the cfm requirements to feed a smaller engine are less and most will find it easier to get the best all around performance from a single 4 barrel. That said for ultimate performance a dual 4 setup (with carbs sized appropriately for the engine) will likely result in the highest overall HP if tuned properly. But as you've noted, most people are either too lazy to go through the proper tuning efforts to get there or simply don't know how to do it. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Dragula]
#1288760
08/22/12 10:34 AM
08/22/12 10:34 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
The carb/intake picture I posted above is a complete setup from a 62 300H.Cam is old Crane Commander,motor is .030 over 440 with Ross flat top's,zero deck,rejetted origional 62 carbs,recurved factory tach drive dual point, ported 906 heads and complete 3" Max Wedge exhaust.Lacks a little at low end,the old dual plane factory intake isn't the greatest but for something that I wanted to be drivable it works to suit me.Get's around 16/17 mpg and top end that just keeps going.And,I don't have a fuel problem as it runs on 80% AV gas. ![](/ubbthreads/images/graemlins/eeek.gif)
[Re: 62maxwgn]
#1288761
08/22/12 07:17 PM
08/22/12 07:17 PM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
MEH!
I had the RPM Intake (Still do) with the single 4 750cfm. I had good response. I could put my foot down and move. I started collecting the Dual Quad parts in 2002 and I finally put it on 2 years ago....I love it....I mean really LOVE it. I have dual 500cfm Eddy's. I can cruise with the GV overdrive....4th gear...2200rpm...28" tire...3.55s and the one 500cfm carb is open. My A/F meter hooked up and good numbers. I edge my foot a little further and you can feel that second carb opening, OD switches off, passing gear and more pedal and you have the full 1000cfm. My rear tires get squirrely and it really puts your cheeks in the seat. I got about 18mpg with my RPM/750 setup.....I haven't crunched the numbers (because my fuel gauge can't read right) on the new setup but I would expect the RPM/Dual 500s are putting at about 12mpg at the moment only because I installed my RPM heads and haven't dialed the engine back in with the A/F meter because I still have yet to install my headers...
I have a 505 I am building but for the meantime...the induction setup on this 440 will keep my happy for a few years to come before I decide to build my roller motor
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#1288762
08/23/12 07:26 AM
08/23/12 07:26 AM
2boltmain
Holland MI Ottawa
Around 1995 in the Chrysler Power magazine they featured a man with a 71 ish Charger. It was a street and bracket car. He ran the Edelbrock CH28 and two Edelbrock 600s. He said his car had ET'd better with a big Holley and Weiand Team G but the streetability and low end was better with the dual quads. Dont run duals on the street for the best performance because it was the 40s 50s and early 60s were multiple carbs were better performing than single. Run the duals because they look great and compliment a muscle car better than anything else!!!!!!!!!!!!!!!!
[Re: Cab_Burge]
#1288764
08/23/12 05:35 PM
08/23/12 05:35 PM
62maxwgn
Blair County,PA
I have had a car with both a single carb. on a dual plane intake and a stock single plane dual car. intake with stock carbs. with progressive linkage. The single four combination drove a lot better than the dual four barrel did until I hooked the dual carbs. up so they both opened together, not progressively I have done that on several other cars wiih good success
But I bet you can't get 16/17mpg !! ![](/ubbthreads/images/graemlins/biggrin.gif)
#1288766
08/23/12 11:14 PM
08/23/12 11:14 PM
bobs66440
Thanks for all the input guys. Sounds like I can make this work, but I don't know if they are tuned to the ultimate performance. I don't have a A/F ratio meter, so I guess it would be hard to do. Though I know how to set the idle using he vacuum meter. I'm running the Offenhauser intake, which I don't like much because the carbs are spaced so far apart on this manifold compared to others, that I can't use the nice Edelbrock progressive linkage setup because it's too short to reach carb to carb. I'm using the cheapo rod/set-screw stop style. It works, but looks cheap. I have it set up so the secondary carb starts to come in after about 20 degrees of rotation of the primary throttle. Then they both reach full throttle at the same time. I have read the plugs and they look great (light brown) except for two that look almost brand new (no color or deposits). I haven't looked at them for 800 miles or so (the engine only has a little over 1000 miles on the rebuild), they may be different now. Because of this and the fact that it seems to run well, I assumed that they were pretty close in tune, but maybe not. I will do a little research and see if I can get them closer. I've read the tuning instructions in the Edelbrock manual a few times over and for some reason my brain isn't completely grasping the whole theory of the metering rods and all the functions. The instructions seem a little confusing to me. Maybe I'll call their tech line and see if they can explain in layman's terms. ![](http://i814.photobucket.com/albums/zz65/bobs66440/PICT4231.jpg)
