Re: Lost Oil Pressure
[Re: Dodgem]
#1287707
08/19/12 12:11 PM
08/19/12 12:11 PM
RapidRobert
What Dodgem said. If good there pull the dist/inter shaft & drill prime it (CCW) & go from there
[Re: RapidRobert]
#1287708
08/19/12 01:32 PM
08/19/12 01:32 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Had this issue with my wagon. Ran at 80lbs cold 60lbs hot. Shut it off one time, started it up awhile later, valve train noise and 30lbs of oil pressure. I was at a show when this happened. I pulled the valve cover, check the valve train, all was good. I put it back together, started it up, and the oil pressure was back to normal. Changed the oil and filter after that. Could have been something got in the pump or filter. who knows.
I had a 400 pontiac once that every so often when you started it, it would make valve train noise. If i changed just the oil filter, it wouldn't do it again for like 4 months.
I'd change the oil and filter first, and see what happens.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Dodgem]
#1287710
08/19/12 01:43 PM
08/19/12 01:43 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Pull the valve covers maybe bent a pushrod then kick a lifter out! The lifters seem to kick out on start up think they lose their oil seal??
Yes, lifter not in its bore as described, or oil pump drive shaft failure, or or pick-up tube failure.
[Re: stinger]
#1287713
08/20/12 08:39 AM
08/20/12 08:39 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Id pull the dist to check the oil pump drive to see if its broken before pulling valve covers..
I am truckless..
