grease fittings - 70 Challenger #1287688
08/19/12 07:55 AM
08/19/12 07:55 AM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I need to replace all of the grease fittings on the front of my 70 Dodge Challenger. Does anyone know what size threads I should be looking for when I go to the parts store??
Thanks!
Re: grease fittings - 70 Challenger [Re: faud88] #1287689
08/19/12 09:40 AM
08/19/12 09:40 AM
IN
ahy Offline
ahy  Offline
IN
The fittings are the smaller of the two common thread sizes. Its easiest to get an assortment package with different angles.
Re: grease fittings - 70 Challenger [Re: faud88] #1287690
08/19/12 09:53 AM
08/19/12 09:53 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I think the zerk fittings thread can vary depending on who makes the part. I know they do on truck parts.
I'm kind of thinking... if you need new grease zerks, then I bet you might need some new front end parts. Which might be easier then replacing all the fittings only to find out some of them are wore out?
