68 Dodge Coronet R/T stripe installation #1287501
08/18/12 07:39 PM
08/18/12 07:39 PM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
i just ordered my R/T stripe kit for my car, i have studied and talked to some people on how to install. i know the best thing is to keep it wet with soap & water and to take masking tape to mark off where it goes.
can you guys give me some tricks and some do's and do nots? a fellow member has emailed me the factory specs on it, i know it is 4 5/8" from the rear of the decklid and the stripe must align with the indention of the bumper on the quarter.
this is the last thing to finish up the 4 1/2 year restoration.
Re: 68 Dodge Coronet R/T stripe installation [Re: cornet684me] #1287502
08/19/12 01:30 AM
08/19/12 01:30 AM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
My recomendations:
1. Buy a brand new plastic bondo spreader to smooth out air bubbles
2. Measure more that twice-cut once
3. Take plenty of time
4. Remember to wrap the stripe under the trunk lid and tuck it down into the trunk gutter
5. Remove any wax from the paint where the stripe will be
6. Pull the paper off of the stripe slowly and at a sharp angle in line with the stripe to avoid pulling the stripe up
7. Tiny bubbles that just wont go away can be poked with a needle to allow them to flatten out
Good luck!
Re: 68 Dodge Coronet R/T stripe installation [Re: wesgtx440] #1287503
08/19/12 08:04 PM
08/19/12 08:04 PM
Brandon, Ms
Brandon, Ms
thanks, i will take my time, i have done everything else on the car, the vinyl top was fun
thanks
Re: 68 Dodge Coronet R/T stripe installation [Re: cornet684me] #1287504
08/20/12 12:43 AM
08/20/12 12:43 AM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
Did you do the vinyl top yourself? I have a '68 Charger that will need a vinyl top soon. How bad a job is it?
Re: 68 Dodge Coronet R/T stripe installation [Re: moparjo68] #1287505
08/20/12 05:19 AM
08/20/12 05:19 AM
Ashville, Manitoba, Canada
superbeeman69 Offline
super street
super street
I use 3 drops of dawn dish soap (or any fancy smelling dish soap your wives may have, i wont judge here) per 24oz spray bottle of water. Provides the best amount of slide/stick for the decal. When your happy with where its placed, start squeegeeing out the liquid and air from the middle, outwards. Or if you have measurements, make an L shaped template with 1/2" masking tape and again, once your happy with the placement, start squeegeeing out the air and water from one end and work to the other using the template to ensure correct placement based on your measents. Hope this helps. This method has always worked for me.
1970 FM3 Coronet 440, 1971 FJ6 Dude D100
Re: 68 Dodge Coronet R/T stripe installation [Re: moparjo68] #1287506
08/23/12 12:47 AM
08/23/12 12:47 AM
Brandon, Ms
Brandon, Ms
yes i put the vinyl top on myself, in fact i built my car in my 2car garage in the middle of a subdivision, took me 4 1/2years and maxing out around 3 credit cards,
the main thing with the top is the measurement down the center of the of the top , and glueing down the center and working out from the center on each side, taking your time and rolling out the bubbles , i used a vinyl floor hand roller to roll out the top
Re: 68 Dodge Coronet R/T stripe installation [Re: superbeeman69] #1287507
08/23/12 01:10 AM
08/23/12 01:10 AM
Brandon, Ms
Brandon, Ms
thanks superbeeman69
and thank everyone for the input, i will post the results, i am a little nervous about how the stripe is going to lay down in the trunk seams
Re: 68 Dodge Coronet R/T stripe installation [Re: cornet684me] #1287508
08/25/12 06:35 PM
08/25/12 06:35 PM
Brandon, Ms
Brandon, Ms
it was hard as heck, it is off about 1/2, the reproduction stripe is about 1/2" off, however, i made it work, it is not a show queen but the every day person will not even see it
Re: 68 Dodge Coronet R/T stripe installation [Re: cornet684me] #1287509
08/25/12 06:36 PM
08/25/12 06:36 PM
Brandon, Ms
Brandon, Ms
another
Re: 68 Dodge Coronet R/T stripe installation [Re: cornet684me] #1287510
08/25/12 10:08 PM
08/25/12 10:08 PM
super street
super street
Looks great!
Re: 68 Dodge Coronet R/T stripe installation [Re: superbeeman69] #1287511
08/25/12 10:20 PM
08/25/12 10:20 PM
Brandon, Ms
Brandon, Ms
Thanks Man, just got back from a rained out cruise in, everybody love it too
Re: 68 Dodge Coronet R/T stripe installation [Re: cornet684me] #1287512
08/25/12 11:27 PM
08/25/12 11:27 PM
SE Pa.
LimeliteAero Offline
SE Pa.
another
Re: 68 Dodge Coronet R/T stripe installation [Re: cornet684me] #1287513
08/26/12 08:16 PM
08/26/12 08:16 PM
Mcgregor, Ia
493RT Offline
493RT  Offline
Mcgregor, Ia
Looks good !!
Re: 68 Dodge Coronet R/T stripe installation [Re: 493RT] #1287514
08/27/12 01:38 PM
08/27/12 01:38 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Looks great. I just replaced the side stripe on my Challenger. First time I ever attempted this myself. I think it was pretty easy to do, time consuming but not to bad. It was just like putting on a giant sticker. I am more than pleased with the results.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 68 Dodge Coronet R/T stripe installation [Re: 6PKRTSE] #1287515
08/29/12 12:23 AM
08/29/12 12:23 AM
Brandon, Ms
Brandon, Ms
Re: 68 Dodge Coronet R/T stripe installation [Re: cornet684me] #1287516
09/04/12 12:56 AM
09/04/12 12:56 AM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
Nice Job!!!
